New to FTE and Diesels trucks Eau Claire WI
just wanted to say hi. i have been reading other post for a while trying to learn. i just bought my frist diesel truck a 2000 F-350 regular cab with a 7.3 turbo diesel. i have a 8" lift with a edge juice with attitude chip and programmer in it. otherwise its stock. looking forward to getting to know people and learning about diesel trucks. hope everyone had a good holiday.
Micah <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
He can't have a sig unless he ponies up to be a member or gets to 25 posts...
The trans is controlled by the PCM, and your PCM is controlled by the Edge now. The extra power can be very harmful to the transmission, unless steps are taken to help the trans out in tuning. Also, the larger tires will definitely stress it out, unless you re-gear for them.
i was planning on putting in lockers and new gears ( 4.56 ) when i put the bigger tires on this comming year. what are some things i can do the tranny to help from causing any damage to it ? im from Eau Claire Wi. ( west central wi ) is there any good diesel shops that are good or people would recommend ?
mic
mic
The gears, first & foremost. Then look at getting CUSTOM tuning. Canned tunes from Edge won't make nearly the power you'll get from a custom tuner. Plus, they'll help with the trans. Next, look at a larger trans cooler, and a mod'ed accumulator valve body. If you're reasonably mechanically inclined, look at the TransGo kit. I absolutely LOVE mine, and it wasn't all that hard to do.
thanks for the advice i will look into the custum tuning and tranny stuff.
mic
mic
mic
