P04xx series codes
P04xx series codes
Just another newb question,
I was wondering what would set off P0472, P0478, P0470? I cleared the codes using my old edge evolution (handheld one) was not running a tune at the time and the codes have not come back. Could it be the EBPV tube getting clogged up or would there be any other major problem that will bite me in the rear end? I did some searches but none turned up all three codes registering at one time.
Thanks,
Thanks,
If they don't come back I wouldn't worry about them but it wouldn't hurt if you did this maintenance procedure. and checked the items in bold for P0478. These could cause the P0472 and P0470.
Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
P0478 - EPR Exhaust pressure control valve high input - Plugged sensor line, stuck butterfly, restricted exhaust
P0472 - EBP Exhaust back pressure sensor circuit low input - Open/grounded circuit, biased sensor, PCM
P0470 - EBP Exhaust back pressure sensor circuit malfunction - Biased sensor, open signal return
All that cranking to start sounds like your GPR is not working. That white smoke is raw diesel fuel that is not igniting due to cold combustion chambers. Glow plugs not getting hot.
Since the P04xx codes returned the first thing you should do is the EBP Sensor and Tube cleaning. That link I posted will guide you.
This is what my GPR looked like at 82k. It still operated but the contacts were so pitted it did not pass power to the GPs.
Restlesswildman
09-23-2014 07:23 PM
jamillertriathlete
Modular V8 (4.6L, 5.4L)
12-06-2002 11:28 AM
