Exhaust ??
Old 03-22-2000, 12:06 AM
BigBrownTruck's Avatar
BigBrownTruck
BigBrownTruck is offline
Exhaust ??
Old 04-01-2000, 09:05 AM
Joel_2's Avatar
Joel_2
Joel_2 is offline
Exhaust ??
Does anyone have any recommendations on exhaust? I just finished my motor (351M) 79 F150 4WD Extended Cab. (With lots of help from you guys, thanks by the way, runs great!!) Anyway, I was considering headers and you guys recommended stock manifold with dual exhaust. I think of dual exhaust as straight off the manifold all the way back. The truck has a catalytic converter so the exhaust shop wants to run a Y off the converter to the rear. It’s the law, so ……? My question is this just a California law? I am in the Army and being transferred to Montana this summer, would I be better off to wait until I get there or will I be faced with the same problem? Does this really matter, or is this what is meant by dual exhaust? Does anyone have a similar set up with exhaust they are really happy with? I want something that sounds good but does not drive you crazy listening to it!!
Thanks for the help…as always!
Old 04-01-2000, 09:22 AM
Nitro's Avatar
Nitro
Nitro is offline
Exhaust ??
Welcome to Montana!!! You dont have to worry about the converter here. Anything around where I live has dual exhaust and no cats on it. I have had no problems with the emission cops. As for mufflers go with glasspacks. They are inexpensive and they last a long time. I dont know about the headers unless you are running a highly modified engine. Good luck
Nitro
Old 04-01-2000, 11:42 AM
jowilker's Avatar
jowilker
jowilker is offline
Exhaust ??
Joel, each state has different regulations, and Nitro seems to know his state. You will not find a shop in NC that will remove a cat. unless they are replacing it. I beleive it is a federial mandated law, that carries a $50,000.00 fine for removal. Vehicle inspection is where that would be caught if inspected for. I gutted one on a 79 van that I had, and ran it for years. Emission inspections were introduced and the engine would have had to have had all that stuff replaced including the cat, so I sold the truck instead.
I beleave like you that duals are L & R side out to the rear. I am seeing that a connector between the L & R just behind the tranny allows better breathing for both sides. The Flowmaster mufflers make a boss sound. If you can hookup your old system, and run it until you leave Calf. could be a good move for you.
My 2
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: Exhaust ??
