8.8 LSD F150 exploded view diagram?
Old 12-23-2009, 01:59 PM
konasexone's Avatar
konasexone
konasexone is offline
I'm looking for an exploded view of my 8.8 LSD . How many bearings on the pinion shaft? Is there a front one I can get at easily? My Haynes manual doesn't help me here.
Old 12-23-2009, 04:55 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
not exactly , but this will give you an idea of how its made.
Google Image Result for http://z.about.com/d/autorepair/1/0/H/A/42122782.gif
Old 12-23-2009, 04:58 PM
steve(ill)'s Avatar
steve(ill)
the pinion slides in from the rear with 1 bearing, you tighten the crush nut on the front to hold it in and set preload. the ring gear bolts to the planet gear holder, and the clutch pack sets to the side of that... in the photo, you can see the cluthc pack housing.
Old 12-23-2009, 07:14 PM
konasexone's Avatar
konasexone
Thanks. There is also a front bearing which I think can be changed without pulling everything apart. My diff also has a wave spring in it.
rj1983
04-10-2017 06:06 PM
reggiedunlop
1983 - 2012 Ranger & B-Series
12-22-2016 09:19 PM
Marcof150
1997 - 2003 F150
07-01-2016 02:18 PM
buck_
1978 - 1996 Big Bronco
17
09-13-2010 06:44 PM
skinsey
03-02-2004 09:17 AM
Quick Reply: 8.8 LSD F150 exploded view diagram?
