Gasoline/Propane 390 Engine
I'm considering the purchase of a 390 motor that has been run primarily on propane for the past thirty years.
What effects does the propane have on internal engine parts? Do the parts wear the same as would be expected with gasoline? Does propane burn hotter or cooler than gasoline? And finally, what would happen if I began running it on gasoline again after all these years?
Thanks,
Jim
Thanks,
Jim
I'm not sure about the wear of the engine parts or the heat but the propane burns a lot cleaner there should be little or no carbon build up in the engine. to run it on gasoline again all you have to do is take a plate off from under the carburetor and hook a fuel line up.
evan.kelly978
06-12-2012 10:18 AM
pwright0001
16
08-22-2011 06:42 AM
blueeyedfordguy
88
03-13-2010 01:53 PM
