High-speed vibration/grinding noise
Getting that u-joint fixed took care of my problem. They ended up welding in a new yoke, and replacing all of the bearings.
My symptoms were very similar to the ones that you (Jars) described. I was looking all over the front-end for the problem. Turned out that it was the drive-shaft. I'd suggest just pulling the drive-shaft to see if you can see anything abnormal in any of the u-joints or the slip-shaft part, near the carrier bearing. You might find a cracked cup, like I did, or something similar. I never would have found it if I hadn't pulled the shaft off - once it was off - it was obvious that there was a problem.
Well not to kick up an old thread, but I have had a similar issue myself on my 2001 F350 Dually.
Not really a grinding noise more of a rubbing/vibration. If I turn the wheel to the left while under power (going down the road at 40+mph) its much more pronounced.
Going over dips it seems to do it when the load is on, and when its fully off.
I have replaced
Both front wheel bearings and needle bearings, both sides upper and lower ball joints, all the u joints, and the hanger bearing. All 4 shocks are new.
It really feels like its coming from the passenger rear, when I hit a bump on the drivers side everything feels solid, but when it comes to the passenger rear going over a bump it does not feel the same.
Yes I have jacked it up and checked for play and it seems fine. I have even jacked it up and supported the rear end and put it in gear. There doesnt seem to be any noise or vibration when I did that.
I dont know but I think I will just replace the inner and outer rear wheel bearings this weekend and see what that does. :S
I have replaced
What about pulling the rear drive-shaft completely and driving the truck in four-wheel drive. At least then you might be able to exclude the drive-shaft as a possible source of the problem. I'm not sure what speed is okay for driving with only the front wheels engaged, but I would think that 40 mph, for a limited time, would be fine.
You should be fine doing that. Sence your going to have it off anyways check all your u-joints. Im not positive that the drive shaft is your problem, its just one more thing to rule out that wont cost you any money and only 20 mins. of time. I would pull the drive shaft inspect everything grease it up and see if it still makes noise
resq302
08-21-2018 10:29 AM
AaronLane
07-30-2017 09:21 AM
tilopa
09-26-2013 05:15 PM
