Transfer case oil- Mercon V OK?
Got a 01 F250 w/Powerstroke and the manual says to use Mercon oil in the transfer case. It also says that Mercon and Mercon V are not comapatable.
Ford don't make regualr Mercon anymore and they sold me the Mercon V which I didn't realize until I got home. I called them and they say that it will run fine in the transfer case however, it says on the back of the bottle, 'Do not use in transfer cases'.
Has anyone had an issue with changing over to the Mercon V? Do you just drain out as much as you can or did you flush it out before installing the new oil?
I just don't want to take any chances on it not working and doing damage to the case.
Sorry if this is a repeat, haven't been on here in a while. That's why I have a Ford, so I don't have to waste my time looking for answers to problems that pop up ;-).
Don
Don
Very interesting...
I looked through a few years worth of owner's guides and they all say Mercon ATF up to '08, where they switch to "Motorcraft Transfer Case Fluid". Seeing as the '08+ trucks use the same t-cases as the '07 and earlier SDs, I'd suggest trying to get your hands on this Motorcraft stuff.
If it were me I'd simply go to wal-mart and get some Mercon/Dextron and use that. Way cheaper than dealer prices, and they are certified to be Mercon compatible.
And yes, there is no flush for a T-case. Drain, fill, and drive!
Supposibly Ford changed the formulation of the Mercon V but I would trust the writing on the bottle over a guy behind the parts counter, I'd return it. I changed the fluid in my 04' and used 2 quarts of Amsoil's ATF which is universal and a full synthetic ATF. I hear Mobil1 ATF is good stuff also. I don't see any reason to use Ford oils and fluids in my truck when the aftermarket meets or exceeds there specs. I'm pretty shure Castrol still makes and sells Mercon because I have some I got some after the switch.
Thanks guys, that's what I've always liked about this forum is you can get a quick and decent answer.
Makes me feel better about my decision to not use it even though they said it was what they use now. Of course they are a dealership and have no problem selling you a new transfer case if yours goes bad. I just happened to be near there one day and didn't feel liked driving anywhere else to go get some.
I'll see what else I can find that matches up.
Don
Don
I like youir little transfer pump, didn't know they made such a thing. There have been many times in the past that I could have used a pump like that, but glad I don't do that sort of thing for a living anymore.
I like the part in the write up about not using air tools, does this mean I shouldn't hammer the plug into an aluminum case with my 1/2" impact? ;-)
Don
Don
I bought one for my rear differential's lube, but for lightweight ATF you could use a shampoo bottle dispensing top and some clear tubing with a tie-wrap.
It would just take a bit longer, but you're only pumping two quarts.
Yea, that's what it means. Of course, if you want to........
Pop
Pop
How sad that our 2000 F250 doesn't look like that now it full of crusty rusty flaky no black coat on steel it peel off.
What I learn about any type of ATF. They have different chemical and friction which could harm to transfer case. It best to follow bottle and manual book in drawer on truck.
Mecron V should be ok.
Use an allen wrench on the plugs. I used a wrap and a half of teflon tape (for pipe fittings) on the plugs just to make shure they are sealed.
You can buy a simular pump for about $10 in the Wal-mart boat/marine section. It is marketed as a gear lube pump. Just cut off the fitting that screws into the boat engine and you are done. It will fit any oil or gear lube bottle on the market.
About that little pump sold at Walmart, yes it is a pump to service outdrive lower units. You don't have to cut off the steel fitting at the end of the tube, just make sure the washer does not fall off and into the case. I just insert the end an inch into the case fill hole and pump away. Sure beats spilling the new fluid all over the place. Thnk I might try the Mobile1 this time around.
