need HELP with DIY high idle (potentiomer/switch)
im doing the high idle currently and im confused.
im using this page with cookies instructionshttps://www.ford-trucks.com/forums/2...-2002-psd.html
I have a 5k pot, without switch, im going to use a switch i have drilled in the dash currently (nothing hooked up to it)
so how do i wire the switch to the pot? it has 3 (hoops?) whitch do i put it in?
Also the resistors, how do i hook them to the pot? does the resistor go through a hoop?
sorry, if anyone has a picture of this or advice it would be very much appreciated.
thanks
thanks
on
The switch is really independent of the potentiometer. The switch is to connect the two sides of the idle validation switch, on the pedal assembly, to "fool" it into thinking your foot is on the pedal. Make sense? I didn't hook anything up to the park brake. I followed the same instructions as Scott. No relays involved, unless you want to activate it by the park brake switch.
C&P'd from the instructions: Using the 3M tap connectors, parallel the switch on the pot to the red wire with yellow stripe and the red wire with green stripe. It doesn't matter which terminal on the switch goes to which wire. It's only a switch. By the way, this is called the TVS, throttle validation switch.
Now, using the 3M connectors again, tap into the grey wire with the white stripe and hook it to the center connector of the potentiomer.
With another 3M connector, hook the brown wire with a white stripe to one end of a resistor. Hook the other end of the resistor to the left side of the potentiomer, looking from the shaft side. This is called the TPS Throttle Position Sensor.
Connect your switch here by running wires to these two wires to complete the circuit.
ok i got the red/green and red/yellow hooked to a switch, but where is the grey/white and brown/white?
i see now, i thought i had to hook the switch to the pot.
i guess im dumb, but i cant find the grey and brown wires.
thanks for the help!
edit: also so there will be nothing on the right side of the pot?
on
Got the wires figured out?
havent figured wires out yet, think i may have found a post with a diffrent year, so may be able to find wires.
i had ordered my dp tuner with 1200 high idle and no start, for some reason it never came with it... i dont want to send it back as it is expensive to ship across the border. but i'll have sometime.
jeffreyclay
02-01-2016 03:46 AM
K.Ray
03-20-2014 09:49 AM
kyle j
08-02-2011 12:12 AM
strokersace
03-18-2008 12:08 AM
