changing batteries on a diesel X
Old 12-06-2009, 10:38 AM
Love Diesel X's Avatar
Love Diesel X
Love Diesel X is offline
Is there a preferred process when installing new batteries on the diesel to not lose the electronic settings?? keypad, radio, etc??
Thanx!
Old 12-06-2009, 10:41 AM
soutthpaw's Avatar
soutthpaw
soutthpaw is offline
as long as you only change one at a time and leave the other connected you wont loose your settings .. remember that the + side will be live the whole time so don t touch it to the chassis or metal parts
Old 12-06-2009, 10:47 AM
Love Diesel X
Thanx for the fast response
Old 12-06-2009, 06:13 PM
katiesdad7's Avatar
katiesdad7
katiesdad7 is offline
Walmart batteries are good and cheap.
Old 12-10-2009, 09:35 AM
njstevens's Avatar
njstevens
njstevens is offline
Make sure you buy a quality set of batteries. Especially if you live somewhere it gets pretty cold. Takes a lot fo juice to egt the glow plugs gowing and to crank that diesel. I have alwasy believed you pay peanuts you will get monkeys when it comes to batteries.
Old 12-10-2009, 11:07 AM
psajunk's Avatar
psajunk
psajunk is offline
Mine too
170k miles on 2004 EB.
Looking at Optima yellow tops, Do I need to replace both together?
Dealer said only pass. side tested bad?
Thanks
Old 12-10-2009, 01:58 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
If you can afford it, rule of thumb is to replace both at same time.
Stewart
Old 12-10-2009, 02:21 PM
Downriver Thunder's Avatar
Downriver Thunder
Downriver Thunder is offline
Odyssey PC1750T
Try these, pricey but awesome. Also, when I changed the battery in my 250 I never lost any settings on the keypad or radio but radio is stock. Just had to reset time which is no biggy.
Old 12-11-2009, 08:06 AM
m350's Avatar
m350
m350 is offline
Last yr,,,October or so,,my 06' F-350 six-O,,,had a sluggish start when getting cold,,,checked batteries,,,Pass side,,battery was toast,,,Driverside was fine,,,so I just replaced the one battery,,,,,as of Now,1 yr plus later,,,driverside original battery still going strong ! I replaced the bad one with another MotorCraft original type 850 CCA I beleive. Good Luck!
I have heard of mixed opinion's on Optima Batteries,,,and one opinion was from a Store clerk ,,,where they Sell and see the returns of the Optima batteries ! Good Luck !
Old 12-11-2009, 01:24 PM
X-Hibition's Avatar
X-Hibition
X-Hibition is offline
Eight years on the Optima in my Sub, and it is just now time to replace. I think I made out well.
And the preferred method for diesel battery swaps is to change both at the same time. Leaving a weaker, older battery in place will negatively (battery humor!!) impact the fresh, new one. You own a diesel, spend the money.
Old 12-11-2009, 03:18 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by Downriver Thunder
Odyssey PC1750T
$265 for one battery! Pricey is an understatement!
In a cost vs. cost scenerio, unless they can guarantee that battery will last AT LEAST 12 years, there's no way it's worth it for a normal, everyday driven vehicle with normal electrical demands.
Stewart
Old 12-13-2009, 12:31 PM
BigBlue15's Avatar
BigBlue15
BigBlue15 is offline
Just the same as you would never want to replace just one tire on the same axle you always want to replace both batteries. Ultimately the older battery will tax the newer one. Your best bet is to find a gasser and put your second still good battery in that rig. And just my opinion of course, had the yellow top optima batteries and i say leave em on the shelf. Running two MTP65 Interstates and they are treating me well so far.
Old 12-14-2009, 09:38 AM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
When the 05's batteries went south after 5 yrs, the Walmart replacements were an inexpensive and easy fix... $74 apiece and they swapped them out while I shopped
Sometimes paying more is just paying more
SBV45
2009 - 2014 F150
01-06-2022 06:36 PM
stufarmer
1999 to 2016 Super Duty
24
01-08-2017 04:21 PM
rich gill
07-19-2010 04:46 AM
Skaning1
2009 - 2014 F150
05-21-2010 05:03 PM
esco24
10-24-2009 07:08 PM
Quick Reply: changing batteries on a diesel X
