Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Sign in using an external account
Register Forgot Password?
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
  #1 (permalink)
Old 12-05-2009, 11:31 AM
njneer1's Avatar
njneer1 njneer1 is offline
2000 Ford Excursion
My Garage
njneer1 has a great reputation on FTE.njneer1 has a great reputation on FTE.njneer1 has a great reputation on FTE.njneer1 has a great reputation on FTE.njneer1 has a great reputation on FTE.njneer1 has a great reputation on FTE.
Ex front swaybar endlinks?
Can't find any place that lists the replacement bushing kits for the 4x4 Excursion. For F250/350 you just press the old ones out and replace with the energy susp kit....will these F250/350 ones work on an EX ? same size etc?
  #2 (permalink)
Old 12-06-2009, 09:06 AM
EX40 EX40 is offline
Garage is empty, add now
EX40 is starting off with a positive reputation.
Yes they will. I just did mine a couple weeks ago. Found them on Amazon for $34.70 I believe it was. Do a search on Energy Suspension kit 4.5186G. That's how I found mine.
  #3 (permalink)
Old 12-06-2009, 09:29 AM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason is a splendid one to beholdSkySkiJason is a splendid one to beholdSkySkiJason is a splendid one to beholdSkySkiJason is a splendid one to beholdSkySkiJason is a splendid one to beholdSkySkiJason is a splendid one to beholdSkySkiJason is a splendid one to behold
I bought links for F350 and Excursion from powerstrokeshop - both trucks were the same part #'s IIRC (there is a left and a right for the links!). Bushing kits should be the same too!
__________________
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, (4) Dipricol Optix gauges, F650 dash, AF Scangauge, BTS Tunes, Mahle pistons, 910 springs, chromo pushrods, headstuds, 38R, 6637, RR boots, AC codes, SB Con OFE, 255/85/16 M55's!, DIY SVO system, more...
2000 Excursion, Limited, 4x4, 7.3 (4) Optix gauges, AIS, Frybrid/V3 VO system, BTS trans and tunes (500HP someday? donations accepted)
  #4 (permalink)
Old 12-06-2009, 10:24 AM
njneer1's Avatar
2000 Ford Excursion
My Garage
Excellent ! thanks guys......wonder why the Energy suspension site says they won't fit Excursion then ????? They are losing alot of sales from Excursion guys
  #5 (permalink)
Old 12-07-2009, 04:51 AM
99FORD EXPY.'s Avatar
99FORD EXPY. 99FORD EXPY. is offline
99FORD EXPY. is starting off with a positive reputation.
check out MOOG i got brand new links with greaseable bushings for about 57 dollars
__________________
2000 X limited 4X4 V10 4:10 gears,v/b code springs,f/r hellwig sways, 4 bilsteins, rough country stabilizer,prodigy p3,flowmaster 70bb system,slotted rotors ceramic pads,factory fogs,headlight conversion 285/75/16 goodyear wrangler mt/r, kevlar,wireless air bags,blizzard plow,banks headers
  #6 (permalink)
Old 11-20-2010, 12:27 PM
19-kilo's Avatar
19-kilo 19-kilo is offline
2001 Ford Excursion
19-kilo is starting off with a positive reputation.
Just did the Energy Suspension F250 kit (includes the end-links and the sway-bar bushings) and can vouch that the fit is perfect.
As a side note about the install... you can't do the endlink bushing replacement without a press. It took around 1000 psi to press out the old bushings.
  #7 (permalink)
Old 11-20-2010, 02:10 PM
fgials's Avatar
fgials fgials is offline
fgials is starting off with a positive reputation.
don't they sell a new endlink kit with bushing?
  #8 (permalink)
Old 11-20-2010, 06:37 PM
ramsay ramsay is offline
2005 Ford Excursion
ramsay is starting off with a positive reputation.
Sure you can. I did. Large socket and a 3 lb ballpein hammer worked beautifully...Make sure the sway bar bushings are 36mm(45180G). The F-250 has a smaller diameter bar, so they don't fit the Ex. End link bushings are the same as 1999-2004 F-250
4) 2592
4) 2593
4) 15.10.245.39
These are from http://www.suspension.com/fordtruck4wd.html. I bought mine there.
__________________
2005 6.0 Excursion Eddie Bauer 4x4. 265,000 miles. Mods: Updated fuel pressure regulator spring, Edge Evolution, ELC, updated turbo oil drain and pressure tubes, & Rev-X oil additive. Replaced EGR and oil coolers.
  #9 (permalink)
Old 11-29-2010, 11:31 AM
Joe28443's Avatar
Joe28443 Joe28443 is offline
Joe28443
Joe28443 has a good reputation on FTE.Joe28443 has a good reputation on FTE.
I am not at all mechanically inclined but if you replace the whole endlink, you don't have to press out the bushing right? I just purchased the K80043 link kit from Advance as well as the k80202 bushings both by Moog. Did I buy the right parts?
Tags
1987, 2001, 2005, 4x4, 50, 73, bar, bronco, bushing, bushings, excursion, ford, front, k80202, kit, kits, limited, link, moog, suspension, sway
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
