F250 front leaf springs ON! Also 325/60/18's - pics!
Ok, I got these wheels and tires months ago. Found out the hard way just because they fit on an F250 don't mean they'll fit on an Excursion... So, I've had a set of front springs from an '01 F250 that had like 30k miles on them forever. Well, we finally threw on the new springs while doing ball joints, etc the other day and I JUST got a chance to try the big tires again. They fit!! Now looks like about 3" taller blocks for the rear will bring it back to level. I still have shocks (Pro Comp MX6), a rear anti-sway bar and LandYot Radius Rods that need to be installed. Ahhhh, nothing some spare time wouldn't fix....
They are a little close to the plastic under the front bumper, we may need to do a little trimming. Otherwise, they fit great and I like the look of tire filling the fender well. I've only been about 2 miles, so we'll see how they ride. The springs alone were an amazing difference. I really did not expect how much they tightened up the ride - the new shocks should only make it better!
I saw an additional improvement when I installed Pro-Comp MX6 shocks. I keep them on stiffest setting...
You will likely need F350 rear blocks in place of your current ones to keep the rear of truck level - but I would swap front springs and all shocks and see exactly what ya need back there!
looks good. I was wondering what yr of truck wheels came off of??? I have a set of 18's that came off a 2006. My ex is a 2002 with v10. Did you need wheel spacers?
Thanks
Thanks
I think you'd need spacers to use later-model wheels on an Excursion. IIRC, the Excursion kept the old wheel spacing thru 2005 - but without my 2nd cup of coffee, this may be completely WRONG! Lol.
I have an Iron Bull front bumper and a 17,000lb winch that weigh around 300lbs and with the W codes I put on, the front still sits high.
Do a spring bracket flip and you might gain enough to level it out... I think i got 2-3" by doing that. I then built soem lengthened shackles as well. If you do the rear bracket flip, you will gain flexability but lose some payload/towing capacity.
Best front and rear springs for towing
Hey SkySkiJason, I have read a lot about swapping springs on the Ex to F250 springs but not sure what to get.
I don't want to raise my Ex up any but want the best set up for towing. I pull a 31 foot TT that grosses out at about 11,000 lbs.
I also read that if the F250 springs are put on then you don't need the Landyot Radius Rods.
Anyone know the real deal on a great suspension set up, like what year F250 donor to look for? My Ex is an '04 and I have 20" rims and 305/50's on it.
Thanks for all the info and keep the updates coming.......
Afaik, any of these spring swaps are gonna raise your truck. One of the things different about Excursion springs is they provided a lower stance - I've heard to make sure they fit in garages...
You prolly could swap rear springs and play with the spring pack(s) to get a better payload/more control and NOT raise the rear. Radius Rods may not be necessary then - perhaps RAS would be enough??
I will swap rear springs AND install my Landyot Radius Rods. I'm sure just getting rid of the Excursion swishy leafs will make 100% improvement in reducing axle wrap and rear-axle steer - but hopefully someday this thing will have ALOT more HP!!
What shocks are you using? Do have an upgraded anti-sway bar yet? Have you considered RAS? I'm thinking there may be some things you can do to 'stiffen' up the ride without swapping springs.
Sway Bar......I think it's original, not sure.
The truck already seems to sit up fairly high front and rear. Even with the 20" rims there is a lot of clearance in the wheel wells. It might look kinda stupid if it goes any higher.
I've done so many other mods recently I'm trying to keep the cost down and thought the spring swap might be the cheapest way to get better towing control.
