2004 Ford Excusion- Light problem
Have trailer running lights were working and now out along with my back tail lights. All others lights work when headlights are on. As I'm crossing the country, is it possible to "hot wire" my lights from the headlight to the tail light in an effort to be safe until I can get it into the shop. Now nowone can see me in the dark. This connection may also make my horse trailer running lights work too. Not sure and appreciate any assistance.
Thanks
Curtis
Thanks
Curtis
The circuit needs to 1) be fused and 2) not overload the headlight switch & wiring to avoid a nasty electrical fire. The effort to do this safely is about equal to the effort needed to find & fix the original problem.
2x on the above, check the fuses and trailer wiring for shorts.
Buy a box of quality fuses. Use the owner's manual to swap out all fuses for brake, park, signal (under hood on my 2001). Sometimes the tiny fuses look OK but don't pass current. At worst this will waste $2.50 and ten minutes. It may turn the lights on.
First you need to get the truck lights to work while disconnected from the trailer. Then check the trailer. If you have a loose battery, use it to energize 1 trailer circuit at a time using alligator clips, wire, test light.
Use an incandescent test light, not LED. An LED will light on very little current where a bulb will glow dim. The LED will fool you but the bulb will look wrong.
If 2 circuits are having a problem, look for a mechanical problem, ie grossly shorted against trailer frame, or similar. Check the grounds and light sockets. Smegma will re-direct your electrons.
77_F150_4x4
09-01-2012 08:53 PM
Paul curtis
16
07-31-2011 09:28 PM
