Oil Cooler How To...since it's that time of year.
Old 01-11-2010, 10:04 PM
sgrol's Avatar
sgrol
sgrol is offline
Originally Posted by snow ho
Please grade me on a curve. I'm new to the forum.
I have a 2002 F550 7.3 turbo with an annoying problem.an oil cooler leak(go figure)
Long story short...never leaked.. got cold and leaks Drive to shop..Brake clean cooler no leak Reseal cooler and it's good.
Let it sit the weekend got cold ...leaks worse...drive it to shop 2 miles away motor warms up they clean residual oil check and you guessed it ...no leak.
What the hell..Has this happened to anyone else? Please help.. Thank You
What did you to reseal cooler?
  #32
Old 01-11-2010, 11:22 PM
guzzle92's Avatar
guzzle92
guzzle92 is offline
Oil cooler o-rings get hard with age, part of "compression set". When it gets cold, they shrink and leak. Warn the engine up and they expand and stop the leak.
The cycle of expansion and contraction on an old o-ring is tough on them and will rapidly cause them to fail. With the oil cooler, this can spell big trouble when you mix the coolant with the crankcase oil. This problem should be repaired soon.
  #33
Old 01-22-2010, 09:15 PM
WA.Ranger's Avatar
WA.Ranger
WA.Ranger is offline
Crap, I shouldn't have read this thread, now mine is leaking.
  #34
Old 01-22-2010, 10:41 PM
WA.Ranger's Avatar
WA.Ranger
Just got off the phone with Bob, O-Rings on the way! Can't thank you enough for doing what you do Bob, saved me time and money. Rep him for me when you can guy's!
Replacement O-rings for Ford Diesel Engines
  #35
Old 02-27-2010, 08:06 PM
fixitman1310's Avatar
fixitman1310
fixitman1310 is offline
very good write and perfect pictures. im ready to start on mine. thanx alot guys for
the help and info
  #36
Old 03-03-2010, 06:15 PM
BigPapi's Avatar
BigPapi
BigPapi is offline
This morning when I went to leave, as I was warming my truck up, I got white smoke. It cranked easily, on the first try. It has been cold lately, but only like in the 30s, not like -4 or nothing. After it warmed up it quit smoking, and didnt smoke the rest of the day. This evening when I got home I climbed under the truck not knowing what I would see. It looks like on both sides are leaking oil. If I go from the top there is nothing wet. If I go under I can see that below the exhaustg manifolds are 'wet'. It's oil, but could the oil cooler make both sides wet? I'm at a loss.
Theres no coolant in the oil, and no oil in the coolant (that I can tell). What the heck is going on??? It didnt do this until it got cold.
  #37
Old 03-03-2010, 10:53 PM
bdrummonds's Avatar
bdrummonds
bdrummonds is offline
Both sides of the engine can get wet from a leaky oil cooler. If the oil cooler is leaking out of the front the oil tends to follow the crossmember, and pool in the depressions, and the airflow under the truck tends to blow it all over everything.
As for why its leaking, the O-rings have gone through so many heat cycles that they have lost their elasticity. When I did my oil cooler back in Nov. my old orings were very hard and very brittle. I could have re-treaded a shopping cart wheel they were so hard.
  #38
Old 11-21-2010, 02:05 AM
hotweekend's Avatar
hotweekend
hotweekend is offline
It happens to me too! and sure enough it was the O rings. they leaks when is cold and couple minutes after you start your engine, it warm up and seals temporarilly.
I buy a used oil cooler on Ebay, clean it, paint it and change the rings so when i take the bad one away I have the new one ready to go!
The folks at the dealership wanna charge me 1400 bucks to do it
https://www.ford-trucks.com/forums/p...ictureid=51138
  #39
Old 11-21-2010, 02:30 AM
big poppa's Avatar
big poppa
big poppa is offline
These new advanced better quailty o-rings be have now helps a good measure but has anybody though of using a bead of hi-temp black Permatex around both o-rings itself for added measure. I t just sounds like a great idea. Might give it a whirl when mine gives up the ghost..
  #40
Old 11-21-2010, 08:38 PM
WA.Ranger's Avatar
WA.Ranger
I said it once, and I'll say it again. I think everyone on here needs to rebuild there oil cooler due to the age of our trucks. I pulled mine cause it was leaking at the front block to oil cooler gasket, but when I pulled it apart, the green o-rings were so brittle and hard they broke apart with barely any pressure. Very easy job to do.
  #41
Old 11-22-2010, 09:10 AM
cleatus12r's Avatar
cleatus12r
cleatus12r is online now
Butt-Head
Received 1,972 Likes on 1,107 Posts
Not trying to burst anyone's bubble here, but that idea runs along the same lines as using RTV on transmission pan and valve cover gaskets.
DO NOT DO IT. Not only will the "sealant" not help the situation at all, but if you get any of it to actually stick to the o-rings, whatever is left over WILL find its way into the coolant passages and oil passages in the cooler.
Bad idea. Just use the o-rings as they come without adding any "sealant" to them. Feel free to lubricate them as you put the pieces back together (good luck pressing the cooler back together without any lubricant anyway), but don't use anything extra to help seal them.
  #42
Old 11-22-2010, 05:43 PM
lhud's Avatar
lhud
lhud is offline
cleatus 12r,
I must agree with you as I found some high temp silicone in my oil cooler from using some on my water pump R&R. It was not enough to cause a flow problem, but your point is well taken.
  #43
Old 08-07-2011, 02:54 PM
LeoJr's Avatar
LeoJr
LeoJr is offline
What are the earliest symptoms of coolant in the oil or oil in the coolant?
I know that water in oil whips into a gray colored mayonnaise, but is there a way to detect a leaking oil cooler before it gets this bad?
  #44
Old 08-07-2011, 07:15 PM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
Very nice write-up Cody. This is one that I will print and put in my "How To" binder
  #45
Old 08-07-2011, 09:08 PM
lhud's Avatar
lhud
lhud is offline
Another reason for not using any sort of silicone is that the o-rings are designed to move - that's why you lubricate them prior to the installation - not just for the ease of going together.
Quick Reply: Oil Cooler How To...since it's that time of year.
