1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
head swap on 5.4l
Old 11-27-2009, 03:52 PM
slopdogg250's Avatar
slopdogg250
slopdogg250 is offline
head swap on 5.4l
can u put 3v heads on a motor with 2v on them now 5.4l 04 f250
Old 11-27-2009, 07:58 PM
suzuki0702's Avatar
suzuki0702
suzuki0702 is offline
no. 3v computer will not controll your 4r100. nor will your 2v computer control your 3v heads, 3v motors have drive by wire..do a search
Old 11-27-2009, 08:09 PM
todd31277's Avatar
todd31277
todd31277 is offline
not really his ?. he want to know if the heads interchange. i believe the answer is still no
Old 11-27-2009, 09:40 PM
5.4L to Freedom's Avatar
5.4L to Freedom
5.4L to Freedom is offline
Well just so you know, I'm not very knowledgeable about the 3V motors but here's what I do know about head swaps on GM vehicles (granted this could be entirely wrong but...)
First things first, if firing order, compression, and pistons are the same between 2 and 3v motors the computer thing wont matter *if* all the bolt patterns are the same.
I would imagine these are still SOHC heads, and with this you also may have timing chain issues. Are the teeth the same size? Cam timing the same?
Pretty much you need to find out exactly to the T whats different. If they bolt up, piston clearance isn't an issue, cam timing is the same, and the cam gears are the same it really shouldnt matter.
I have heard of guys wanting to put the lincoln navigator DOHC heads on their 5.4's but can never recall anyone actually doing it. Thy usually just take the whole setup. Look into the navigator head subject and it should provide some valuable answers
Old 11-27-2009, 09:47 PM
superdutyduck's Avatar
superdutyduck
superdutyduck is offline
talk to someone who builds high quality race engines!
Old 11-27-2009, 11:07 PM
redford's Avatar
redford
redford is offline
Received 1,565 Likes on 913 Posts
Will it bolt up? Yes.
Will it work? Maybe.
You will run into a few challenges attempting this swap.
First, as mentioned, the 3V computer is designed to control a 5R110W transmission and a 2V computer is designed to control a 4R100 transmission.
Second, your 2V intake manifold won't work. You need a 3V intake manifold.
Third, your 2V computer does not have programming to control the cam phasers in the 3V heads.
Old 11-28-2009, 06:58 AM
slopdogg250
Thanks and so i have the 4r100 trans. that was another question i was going to ask how much tourque can it handle. That is what i'm after more hp and tourgue what can i do to get more. i even looked and the cummins convertion but don't want to change my transmission
Old 11-28-2009, 12:37 PM
5.4L to Freedom
Whipple Charger, Pro Charger, lightning motor, DOHC lincoln navigator motor, headers, cams, exhaust, tune, port and polish, insert a V10 then whipple charge that, 460 (385 series) conversion, and the list will go on
Hummah Zach
2004 - 2008 F150
08-03-2016 08:42 AM
alloro
1997-2006 Expedition & Navigator
06-23-2011 02:33 PM
gospeedracer
02-23-2011 01:21 PM
wall77
11-12-2009 07:36 AM
D
07-30-2001 01:01 PM
Quick Reply: head swap on 5.4l
