2 wheel vs 4 wheel ABS rotors?
looked under my truck. I only saw one brake line to the caliper. But on the driver side, it was kind of hard to tell but I saw what looked like a line T'd into the brake line that went to the caliper. But i couldnt find anything like it on the passenger side, or on the rear. Is this the ABS line?
The ABS "line" is actually a wire to the ABS sensor. The sensor plugs into a hole in the inside, front portion of the spindle, and is retained by a small bolt (10mm if I remember correctly).
Look for the sensor and the wire.
The wire should be affixed to the front caliper's rubber brake line for a short distance with zip ties or similar, but then it will lead off to the front and inside of the spindle, while the brake line leads to the caliper.
USCG1994IDI
1999 to 2016 Super Duty
10-30-2014 09:30 AM
kittyhawk
07-18-2012 05:01 PM
JoeVR5
1983 - 2012 Ranger & B-Series
02-06-2010 05:28 PM
