1996 F250 Gauges
1996 F250 Gauges
Hey guys, having some problems with the 1996 F250 I just bought. When I drove it home the battery, fuel, and oil gauges weren't working. The temp gauge was reading on the highside of the safe zone, despite me upgrading from a single core, to a dual core radiator and the waterpump looking new. I found a blown 30 amp fuse on the panel. I replaced it. Now the fuel, temp, and oil gauges are pegged out, but the battery gauge appears to be working now. Are there any common issues with these trucks I should look into? Do I need a new cluster?
It is a 1996 F250 Automatic 5.8L with dual tanks.
Thanks!
Thanks!
I didn't have a fuse panel at the time, the bottom of the dash was missing. I replaced it though, I am not at home right now, but I will look later.
Where are some of the major grounds on the truck? I've been told the fuel tank sending unit grounds like to go bad, which is why a lot don't work, is this true? And where would I find it.
Thanks guys!
Thanks guys!
Sorry I haven't posted recently, haven't had a chance to work on my truck.
Can anyone point me towards grounds I might check that might be related to my gauge issue?
How do I remove the cluster? I see the 4 bolts holding the cluster to the dash, but there is a cable going into the bottom out of the column, I assume it is for the shift indicator, how do I get that out?
Thanks!
Thanks!
dgf150
05-07-2014 08:54 PM
daghstdrummer
11-12-2013 07:27 PM
scootin
12-22-2003 06:08 PM
