Clutch master cylinder ??? HELP
Hello, my clutch master cylider push rod is completely worn out (where the push rod connects to the clutch pedal linkage). Could I replace only the push rod or do I need to replace the whole Master cylinder? The pivot point on the clutch pedal is pretty worn also. Any suggestions to repair or part numbers to replace this part?
If I have to replace the Master cylinder, what is the procedure? I've heard that you need to bench bleed the new cylinder. I'm really not sure at all about any of the clutch bleeding procedures/
Any help at all would be greatly appreciated!
Thanks
James
Thanks
James
Thanks
James
Thanks
James
I dont have a good answer for you; but I hate to see a Q go unanswered. So try posting your Q here
Brakes, Steering, Suspension, Tires, & Wheels - Ford Truck Enthusiasts Forums
and run search at the top right corner tab above the replies views
Rocky
This is what a lot of them members are using here.
FORD Clutch Rod End PERMANENT Repair powerstroke too. :eBay Motors (item 260510242892 end time Nov-27-09 20:53:40 PST)
Wolf82636
10-21-2010 03:12 PM
cavitation
22
07-14-2010 12:24 PM
marragtop
10-10-2008 08:46 AM
tomcat6
07-08-2006 01:39 PM
