2001 F350 lost injectors on passenger side
Today my mechanic told me i have lost all four injectors on the passenger side. I suspect this was caused by fuel starvation while having trouble with low fuel pressure .
I am considering the remanufactured injectors from Diesel Care & Performance in Tennessee.
Any suggestions?
Any suggestions?
If UVCH is " under valve cover harness", i did ask him to check all the wiring connections as i suspected a poor connection when i brought it to him. I had already replaced the fuel pressure regulator housing as the original had collapsed inside and was unable to maintain fuel pressure.
I do not know what test he ran to arrived at this. He actually said three were not working and one was hit and miss.
My truck has less than 80K miles, any chance the injectors are covered by the 100K warranty?
I do not know what test he ran to arrived at this. He actually said three were not working ond one was hit and miss.
EDIT: The 100k warranty is only for 5 years, which ever comes first. No warranty.
I am highly doubting that 4 injectors with only 80k on them went bellyup at the same time. I also cant see how low fuel pressure would hurt an injector. Now if you said you heard what sounded like a midget with a ball peen hammer banging on an anvil under your hood, then I might lean that way.
Notice the black tape over the red sheathing? Notice the two "wear marks about halfway between the tape and the yellow decal? That's signs of wires wearing through their insulation and valve cover paint, and shorting to the valve cover.
More common than you can imagine.
Check that carefully, as that could cause what you're seeing.
The wires controlling the passenger-side injectors are:
tan/red
brown/yellow
tan
tan/black
The common return wire is orange.
Are any wires of these color codes chafed at all?
If your lucky stars are aligned just right, you may get out of this for the cost of a roll of Scotch 33+ (the best common electrical tape money can buy).
Pop
tan/red
brown/yellow
tan
tan/black
Pop
