428 heads on a 390
Old 11-07-2009, 10:33 PM
BSCowboy's Avatar
BSCowboy
BSCowboy is offline
428 heads on a 390
Hello ya'll,
I am starting to plan my 75 F-150's 390 M rebuild. But, I am curious about putting 428 heads on it. What's the case for putting them on, or keeping the original 390 heads? Also, if I put on the 428 heads, am I most likely going to run into problems unforeseen problems or difficulties in the future, say with headers?
Old 11-08-2009, 05:40 AM
jowilker's Avatar
jowilker
jowilker is offline
BS, Do you want to clarify 390 M???
John
Old 11-08-2009, 07:26 AM
BSCowboy's Avatar
BSCowboy
BSCowboy is offline
Sure, it's the vehicle engine vin code for the type of engine I have. I believe there are two different types of engines available (at least that's what they show at the local parts store), mine is the 4 barrel version or "M."
Old 11-08-2009, 11:12 AM
Hypoid's Avatar
Hypoid
Hypoid is offline
You need to post a casting number/part number. Same heads can be found on a plain ol' 428 and a plain ol' 390. Heads for a 427 are a different critter.
Old 11-08-2009, 01:45 PM
Bear 45/70's Avatar
Bear 45/70
Bear 45/70 is offline
Standard 428 heads are the exact same piece as the 390 heads. If you are talking the 428CJ heads well then yes they will fit and provide a nice air flow increase. However the larger combustion chamber will lower your compression ratio some.
I have a problem with your "M" code. The books lists for "M" the
1962-63 390 3X2 rated at 401 hp and used a mechanical cam,
1966-67 410 used in the Mercury car line and
1969-71 351.
The only other time it shows up is for a 5.4 SOHC CNG.
Old 11-08-2009, 02:07 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
VIN engine code M = 1974/76 F100/350 390 4V.
1974/76 were the only years that Ford offered a 4V on a 390 installed in an F100/350.
1968/76 F100/350 390 2V: The VIN engine code is an H.
The heads used on 1974/76 390's are not the same as 1968/70 390/428 heads with a casting number of C8AE-H.
1974/76 390 2V/4V head casting number prefixes could be D4TE, D5TE or D6TE...some of which depends on whether a smog pump is present...or not.
Old 11-08-2009, 02:13 PM
Hypoid's Avatar
Hypoid
Hypoid is offline
There ya go!
I just looked at the CSK website for a 1975 F-100:
360 CID VIN Y OHV
390 CID VIN H OHV
390 CID VIN M OHV
Old 11-08-2009, 02:25 PM
NumberDummy
Originally Posted by Hypoid
There ya go!
1968/76 F100/350 360 2V CID VIN Y OHV
1968/76 F100/350 390 2V CID VIN H OHV
1974/76 F100/350 390 4V CID VIN M OHV
Clarified it for y'all. See post #6.
Old 11-08-2009, 03:31 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
More like D2TE-AA and only that casting for FE engines after 72 until 76.
Josh
Old 11-08-2009, 03:52 PM
NumberDummy
Josh
You have your opinion, I have mine. I have parts catalogs, do you?
I have over 35 years of Ford parts experience. How much do you have?
You were born in 1978. By 1978, I had accumulated 16 years of Ford parts experience.
You do know quite a bit for a young 'un, but you don't know everything...and neither do I.
Old 11-08-2009, 04:31 PM
draggin the line's Avatar
draggin the line
draggin the line is offline
Well, if you did know everything, you'd know there are actually NO castings past the D2's, just as Bullitt 390 has said. Your parts books are wrong again, Bucko.
Old 11-08-2009, 04:33 PM
Bear 45/70's Avatar
Bear 45/70
Another moron heard from.
Old 11-08-2009, 04:40 PM
draggin the line
I take that to mean you have a photo of the head castings in question? If not, then shut up. The problem with NumberDummy is his claim to 35 years of BOOK experience. For you and he and his other lackies to discount info from people who actually have HANDS-ON experience is spectacularly ignorant.
Old 11-08-2009, 04:51 PM
Bear 45/70's Avatar
Bear 45/70
I just love a 14 post wonder that thinks he knows it all. NOT!
Oh and I was actually alive before there was an FE engine. I remember the introduction of the much proclaimed 352 in 1957, well late 1957 when the 1958 line was premiered. Having been a professional mechanic and a racer, who only ran Ford products, I would suspect that I along with many others here (that would include Numbers Dummy) have forgotten more about Fords than you will ever know. So go put a sock in it until you have enough years at this to not still be in diapers.
Old 11-08-2009, 05:02 PM
draggin the line
You and the Dummy seem to have forgotten that old people like you get Alzheimer's, which pretty much throws your "I remember when" nonsense out the window.
Now, didn't I tell you to shut up unless you have proof? With the shear amount of late 60's trucks made, there must be a bunch of the D4, D5, and D6 heads on eBay. Stop avoiding the issue and back yourselves up. Put down your Geritol smoothie and get searchin'. Hurry up; I just got a cell text from my girlfriend telling me she's pregnant again, and I may have to pack up and move.
Quick Reply: 428 heads on a 390
