The Chebby rocker trick is a cheap upgrade to an engine with a stock cam. If one wants to factor in more lift with a bigger cam it is usually best to do it with a higher lift cam rather than adding the Chebby rockers to an already bigger cam...essentially what dusty said.
__________________
1983 F150 300 I6, Comp Cam 260h and lifter kit, Port/Polished head, Offy DP Manifold, Holley 4160/1848-1 465 cfm, EFI Exhaust manifolds, Walker Y Pipe to 3-Way Cat, generic Turbo Muffler, Recurved DSII, Mallory HyFire 6a & ACCEL Super Stock Coil, Taylor Spiro Pro Wires, EFI plugs.
