Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 11-06-2009, 07:44 PM
mathteach mathteach is offline
Garage is empty, add now
mathteach is starting off with a positive reputation.
Cranks, but won't start
I have a 2000 F-150 Harley Davidson. I came out of the bank and all of a sudden my truck would turn over but would not actually start. All of the electrical inside works fine, but nothing.
It has been suggested that it is the alternator, also possibly a fuel pump problem, maybe a relay or fuse.
Can anyone give me some insight to what this problem may be.
HELP!!!!!!!!
  #2 (permalink)
Old 11-06-2009, 11:11 PM
S.A.L.'s Avatar
S.A.L. S.A.L. is offline
S.A.L. is starting off with a positive reputation.
It's not the alternator.
  #3 (permalink)
Old 11-07-2009, 03:02 PM
shorebird's Avatar
shorebird shorebird is offline
Wage Slave
2008 Ford F-150
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Get some starting fluid spray. Squirt the fluid into the intake and crank the motor.
If it fires the problem is in the fuel system.
If it does not fire the problem is in the ignition system.
Come back and let us know which system the problem is in then we will go from there.
__________________
2001 E-350SD V10 Triton 3.73LS, ROTW 01/02/10
2008 F-150 FX2 Sport 5.4L 3.73LS Scab 145" Wb; '05 & '07 Taurus SEL's
Bryan L. Unique Collision Center Towing & Wreck Recovery Specialist
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
  #4 (permalink)
Old 11-08-2009, 11:09 PM
Scottdl99's Avatar
Scottdl99 Scottdl99 is offline
Scottdl99 is starting off with a positive reputation.
Any updates?
  #5 (permalink)
Old 11-09-2009, 11:04 AM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
2001 Ford Excursion
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
IAC maybe?
If you step on the gas while cranking and it starts, revs, and stays running with your foot on the gas, it's the IAC.
__________________
Excursion & 6.7 Forum Mod Death Row Inmate #21
2001 X PSD Limited, 203*, HD4R100, GEARHEAD TUNES, MBRP, Hpx, Frx, T500, RAS, Cass Stage I's, 38R w/HFO, M208, 6.0 tc/ic, CFM+, 6 inch lift, 4.10 Gears, Coolant Filter, CAT ELC, AE, Afe 6637, Riffraff Boots. Too much to list, but FAR from stock FTE Guidelines
Quote:
Originally Posted by Toreador_Diesel
Ford didn't call it a "Powerstroke Diesel" becuase they thought it would be a cute name to give a diesel engine...
  #6 (permalink)
Old 11-09-2009, 11:13 AM
JaySVX's Avatar
JaySVX JaySVX is offline
2004 Ford Excursion
JaySVX has a very good reputation on FTE.JaySVX has a very good reputation on FTE.JaySVX has a very good reputation on FTE.JaySVX has a very good reputation on FTE.
If it cranks but doesn't start, it's probably a fuel problem or ignition problem. Check the filters, gas gauge, ignition fuse, ignition relay, fuel pump. Turn the key to on while having your ear next to the fuel pump(may require 2 people or really really long arms) and see if the fuel pump primes. If not, that will cause it. If the fuel filters are clogged and it's not getting fuel, that will cause it. If there's no spark, that will cause it.
__________________
2004 Ford Excursion 6.0
2001 Yamaha Roadstar 1600
1989 Porsche 944 w/400hp LS1
Quote:
Originally Posted by ncheavymetal View Post
But I have an excursion and don't concern myself with matters such as "how much does it weigh?"
  #7 (permalink)
Old 03-15-2011, 09:23 PM
Pinky Demon's Avatar
Pinky Demon Pinky Demon is offline
Pinky Demon is gaining momentum as a positive member of FTE.
Sorry to bring this one back from the dead, but I am having a similar issue.
Vehicle is a 2006 Harley F-150 5.4L 4x2 with 68k miles. I verified the no start condition and narrowed it down to the fuel system via starting fluid in the intake. It ran on fluid but died soon after.
Upon turning the key over, you cannot hear the initial fuel pump start up whine as usual. Checked the fuel pump fuse, it was good along with the fuel filter. I am currently looking for a schrader valve to confirm the lack of pressure in the fuel rail.
Over the phone, dealership believes it is either a fuel pump or a fuel pump control module. (something to that effect, don't remember exactly) The fuel module was on back order, which leaves me to believe this is becoming a common problem.
Looking for any advice please.
__________________
2002 F-250 V10 CC
Click HERE for my full review w/ pictures of the Banks Powerpack Exhaust System.
  #8 (permalink)
Old 03-16-2011, 12:33 AM
Tom.root's Avatar
Tom.root Tom.root is offline
1978 Ford F-150
My Garage
Tom.root is starting off with a positive reputation.
Back yard diagnosis, Crank over engine while somebody bangs on the fuel tank with a rubber mallet. If it starts the fuel pump is bad for sure.
  #9 (permalink)
Old 03-16-2011, 10:12 PM
Nealcrenshaw's Avatar
Nealcrenshaw Nealcrenshaw is offline
1994 Ford F-150
Nealcrenshaw is starting off with a positive reputation.
its the fuel pump
__________________
A MAN AND HIS TRUCK.. ITS A BEAUTIFUL THING !!
  #10 (permalink)
Old 03-17-2011, 06:19 AM
shorebird's Avatar
Wage Slave
2008 Ford F-150
The module is notorious for having the connections corrode.
I went to start my van Sunday and it cranked but no start.
It has been sitting up for a while.
Had the wife crank it while I sprayed starting fluid into the intake.
It started and ran as long as I kept spraying the fluid.
I'll be taking it over to my friends shop to drop the tank and replace the fuel pump.
__________________
  #11 (permalink)
Old 03-19-2011, 12:23 AM
Thanks for the advice gentlemen, but it was the fuel pump control module. Apparently, Ford mounted them on the frame above the spare tire. Water runs off the frame rail and corrodes the back of the module. Ford's fix is a two stage bolt that allows it to drain out the back as well. Why we need a fuel pump control module is another question entirely.
From what I understand, this is the most prevalent issue on the 150s that have this tech installed. Most dealerships I called didn't even stock a fuel pump, all they had was the modules. Truck runs good, but something happened to the sending unit in the process. Time for disassembly again.
__________________
2002 F-250 V10 CC
  #12 (permalink)
Old 03-20-2011, 06:49 PM
catman65's Avatar
catman65 catman65 is offline
catman65 is starting off with a positive reputation.
I just purchase a used 2002 put about 100 miles on it before it shut off about a block from home. It has fuel pressure (30 with engine stopped and just over 40 while cranking)
It does try to start but will not stay running. Is this similar to your symptoms? i couldn't quite make it out exactly in your post. I have no faults at all.
Thanks for your input.
  #13 (permalink)
Old 03-20-2011, 11:06 PM
Not at all. Mine just stopped dead one day. Could not get it to run period. I doubt your 02 has a FPCM. I think they started them in 03 or 4. On mine, it was covered by the spare tire and bolted to the frame rail with a pigtail harness running to it.
How does the fuel filter look on your 02? I would start there and then go to quality of fuel being used. How many miles?
__________________
2002 F-250 V10 CC
  #14 (permalink)
Old 03-22-2011, 10:45 AM
catman65's Avatar
My '02 has 66k miles on it, just purchased it so not sure on the past maintenance or the filter for that matter. I sent it back to the dealer where i purchase it hope to have an answer today so i will let you know what was found.
Thnaks
  #15 (permalink)
Old 03-22-2011, 09:03 PM
Please post up the results. I'm interested to find out.
__________________
2002 F-250 V10 CC
Tags
10, 2003, 54, 99, cranks, f150, f250, ford, harley, start, triton, truck, turn, v10, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
