Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2009, 10:52 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke MoyockPowerstroke is offline
MoyockPowerstroke is gaining momentum as a positive member of FTE.
Caliper hanging up...can I test them?
I have been having a brake gremlin show up every so often between my drivers side front and rear calipers. I haven't seen anything on the front since changing the brake hoses....probably need to do that on the back now. I have flushed the system...turned all four rotors, put on all new pads, re-lubed the glide pins, painted the e-brakes springs and tensioner in rear with nickel anti-seize compound...not sure what else to try. My rear drivers side is driving me crazy. I am to the point of replacement @ only (82K miles?)...Is there a way to check the calipers to see if they're okay...or should I just go ahead and replace? I know, the rotors could be warped, so replacing them too would be in order. I've checked the temps on the rotor that is hanging up and its around 650'F...probably not good. Let me know if you think I should replace them, and if so, any suggestions on where to get the replacements from. Thanks.
__________________
Real Trucks Don't have Spark-Plugs '05 6.0L, 84k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto, Coolant bypass, ZooDad, HighIdleMod, BullyDog 4" TB 4"DP (BullyDog ate Kitty), SCT SF3 Perf Strat.w/Edge Insight for gauges, 24" Wipers, '08 Diff Cover, Upfitters, Skyjacker/Russell brakes lines, M/C Max 100 BXT-65-850s, Mobil1 Syn 5W-40, Wagner ThermoQuiet's, Stanadyne Perf Add & FPPF Lubricity+Power Add., Prodigy Brake Controller, Nitrogen filled Bridgestone Dueller A/T Revo's, Satellite radio, Sun-visor.
  #2 (permalink)
Old 11-03-2009, 07:02 AM
m350 m350 is offline
m350 is starting off with a positive reputation.
If you touch your rear wheels and there Hot,,,You prob have a Brake issue,,,I recently did my rear brakes on my 06' F-350,,,slide pins were free and greasy,,,collapsed each caliper OK,,,installed New pads,,,and RR was froze up 20 miles later,,,smoking HOT,,,Got a re-built from CarQuest,,,$66 bucks with old core,,,Installed and rear wheels are now Cool after driving!
My buddy mentioned,,,the caliper pistons get some rust on them,,,and after collapsing them,,,they sometimes dont release,, when taking your foot of the Brake pedal,,,New Pads,,,thicker,,,hence smoking Brakes !
PS...My RR brakes were sqeaking,,,46k miles,,all is quiet now,,,,Fronts Next !
__________________
06' F-350 XLT SC, S-Bed, 6.0, Auto, man-hubs
04' Explorer NBX, 4.6, auto, 3:73 LS
68' Torino, 289, 4 gear
Tags
2006 , brakes , caliper , check , drivers , f250 , f350 , front , hang , hanging , rear , replace , seized , side , smoking , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
