Glow Plug Relay
Old 11-01-2009, 11:54 AM
rmilchman's Avatar
rmilchman
rmilchman is offline
Glow Plug Relay
I'm trying to trouble shoot why the engine doesn't start easily when it's cold. I figured the best place to start is with the relays. Are they the two relays next to the fuel bowl (I have an '02)? Each one has 4 wires. 1 going to the battery, 1 I assume goes to one bank of relays, 1 I assume is ground and 1 I assume is from the key. The ones coming from the battery have a boot on them that appears to be melted to the relay, and when checking with a light I don't see any power come out of the other large cable.
Is there a fuse somewhere that I can not find? Or should I bight the bullet and replace both relays?
Thanks
Old 11-01-2009, 12:10 PM
jakescars's Avatar
jakescars
jakescars is offline
not sure on the 02 but on my o1 the relay that is closest to the firewall is the gp relay and should have current under the rubber boot all the time but the opposite large post should only have current when the key is first on and only for about 120 seconds max. The small post closest to the firewall should be the pcm lead and the opposite post is the key on post.
Old 11-01-2009, 04:20 PM
rmilchman's Avatar
rmilchman
I have two relays that look exactly alike. Does the '01?
Old 11-01-2009, 04:30 PM
7.3 Rocket's Avatar
7.3 Rocket
7.3 Rocket is offline
The one closer to the front of the truck is for the air intake heater and the one closer to the rear is the glow plug relay. You should see power to the booted post 100% and power to the one without a boot when the GPR is active.
One way to test to see if it's the GPR that's the issue is to take a screwdriver and cross the posts on the GPR for 30 seconds or so and then see if the truck starts easier.
Old 11-01-2009, 04:53 PM
hucka1a's Avatar
hucka1a
hucka1a is offline
Old 11-01-2009, 05:04 PM
danskool's Avatar
danskool
danskool is offline
Go Bills !
As Said above..
12v under the big wire with a boot, Always. Turn the key on and the apposite Large post will will also get 12v. If the relay is working correctly.Using the negative on the battery for your negative for your light.. If no voltage on the opposite side large post when you turn your key on (with a cold truck) would suggest a bad relay. Very common.
Sounds like you have a bad relay.. I would replace it with a stancor. You will never have to monkey with it again.. Stancor is built for life.
Welcome to guzzle's Stancor GPR replacement Mod Web Page
Old 11-01-2009, 05:14 PM
rmilchman's Avatar
rmilchman
Thanks I'll get out there next weekend and do some more trouble shooting based on the link above.
Old 11-02-2009, 09:20 AM
rmilchman's Avatar
rmilchman
I assume both relays cycle about the same amount of time throughout the life of the vehicle. If I find that the GPR is faulty, should I replace both?
Old 11-02-2009, 09:42 AM
megawatt00's Avatar
megawatt00
megawatt00 is offline
The AIH very rarely comes on. It is used to warm up the intake air in very cold climates to reduce smoke.
Old 11-02-2009, 09:45 AM
rmilchman's Avatar
rmilchman
Thanks, Hopefully I will get outside this week to check the GPR. Most likely it will have to wait for the weekend.
Old 11-02-2009, 09:47 AM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
LIke Jim said, the AIH relay is not worked nearly as hard as the GPR. I would not even worry about it. A lot of us delete the AIH system altogether.
GrislteStick
07-20-2017 11:31 PM
Lyle Murphy
01-05-2016 06:00 AM
war1ock
1997 - 2003 F150
04-07-2015 02:15 PM
RFD_Truckie
Electrical Systems/Wiring
07-10-2009 06:00 PM
thehawk75
10-26-2008 10:03 PM
Quick Reply: Glow Plug Relay
