Early Job 1 transmission question
I have an early Job 1 (04/07) 08 6.4L CC with a 5R110 that has the remote mounted external filter. I know I need to change the fluid sooner with this type of filter, but do I also have an internal sump filter? I dont want to pull the pan unless I need to replace an internal filter, and believe it or not the factory Service Manual is not exactly clear on whether the early tranny's with the remote external filter include an internal sump filter. Does anyone know? Thanks
Originally Posted by 2008 Maintenance Guide
Vehicles equipped with the Torqshift transmission and the externally mounted remote filter element, replace the automatic transmission fluid and the externally mounted filter
element (if equipped). Inspect automatic transmission fluid
level on all other vehicles if equipped with dipstick. Consult
your dealer for particular requirements
Thanks for the info as well guys. I have an early 08 as well (01/07) and it needs the trans service.
I noticed the drain plug on the pan. Is there a plug on the converter? If there is I'll do the service myself. If not I'll let the dealer do it.
What has the dealer charged you guys to do it?
Just had the dealer do my tranny, an 05 but same as yours, $133.00 + tx. minus the ext. filter. did that myself after flush. FT-145 filter at dealer $44.71 on line at kmansparts - $20.99. Got two filters for the price of one and it takes about 10 minutes to change. That includes cleaning the filter housing and opening the 1st beer.
The 08'-up trucks that do have an external (not all do, check your bellhousing to verify yours is set up this way) have a different "external" filter than the previous model year trucks. This one is Motorcraft part number FT176 (Ford Part Number = 7C3Z-7B155-B) and retails significantly higher than the older style.
Both lines go through, to and return lines from cooler. I'd like to see one taken apart to see how that works. The whole thing gets changed. (You can see the mount-screw forward towards the oil pan). Only the lines, grey quick connet fittings and that black cradle that swings under it remain on the truck. Right side in pic is a quick disconnect. Left side is threaded. Filter costs anywhere from $80 to $150, depending on where you find it.
