Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > British Columbia
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
British Columbia British Columbia
Join Chapter, Leader: Zip
  #1 (permalink)
Old 10-31-2009, 01:25 PM
Ehkart's Avatar
Ehkart Ehkart is offline
Garage is empty, add now
Ehkart is starting off with a positive reputation.
Tire Sizes!?
So I'm going to need to get new tires for the '91 F250 Diesel soon. I've found that it is equipped with 235/85R16, and I would like to get something maybe a little beefier. Not alot bigger mind you but just a little wider and a tough grip so if I want to I can get anywhere with it. I'm confused as to what I need to do about size differences and my speedo/odometer readings. I've read you just have to keep the overall diameter the same but then how is it that you can put 44" tires on then? So what do I do?
  #2 (permalink)
Old 11-01-2009, 05:11 PM
BC Wrecker's Avatar
BC Wrecker BC Wrecker is offline
BC Wrecker is starting off with a positive reputation.
I have heard you can buy speedometer correctors for use when putting non stock size tires on your truck. Back in the cable driven days, which a 91 might still be.. idk, there was just a plastic? gear on the end of the cable that you could buy with several different tooth counts to help get your speedo accurate again. Better to get one off a parts truck instead of at the dealership... they wanted $42 for the last one i inquired about!!
  #3 (permalink)
Old 11-02-2009, 05:38 AM
Zip's Avatar
Zip Zip is offline
BC Chapter LDR
1979 Ford Bronco
My Garage
Zip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputation
I have heard of those as well.
__________________
Chris,#12 BS'er/Official Slackmaster #7/AVIDEST WINTER HATER
BC Chapter Member/Leader
JOIN THE BC CHAPTER HERE
  #4 (permalink)
Old 11-02-2009, 10:51 PM
Ehkart's Avatar
Hmmm, interesting to say the least. I'll look into this; the father in law says hes pretty sure there should be a Gain control right on the transmission, ever heard of that?
  #5 (permalink)
Old 11-02-2009, 11:17 PM
Zip's Avatar
Zip Zip is offline
BC Chapter LDR
1979 Ford Bronco
My Garage
Can't say I have ever heard of that.
Some tuners have adjustments for tire sizes but probably only for newer ones.
__________________
  #6 (permalink)
Old 11-03-2009, 08:33 PM
BCHauler's Avatar
BCHauler BCHauler is offline
BCHauler has a good reputation on FTE.BCHauler has a good reputation on FTE.
Does the 91 have a digital odometer like the 92-96 trucks?
__________________
Todd - Hockey Dad
1999 f150 sc/lb 2wd 4.2 310,000kms and counting
2001 F250 Crew 4x4 6.8 - sold
94 F150 SC 4x4 5.8 E4OD "Solid Gold" - RIP
  #7 (permalink)
Old 12-30-2009, 08:06 PM
sweetjustice sweetjustice is offline
1988 Ford F-250
sweetjustice is starting off with a positive reputation.
My '88 F250 needed the little nylon driven gear replaced. A stock one was about C$25, but you can definitely find them on the net cheaper and with different tooth counts. I believe the stock one was pink with 21 teeth, but don't quote me on that.
Also, I'm also looking for different tires tires. My stock rims are 6" wide, which seems to mean (at least at tirerack.com) that a 235mm tire is the widest they will accept.
Tags
2001, corrector, correctors, ford, size, speedometer, superduty, tire, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
