Idiots Guide To Shaving Drip Rails and Cab Seams
First of all I am not saying you are and idiot...In this case the idiot I am refering to is me. (or so I have been called)
A few people have asked me how I went about shaving my drip rails and cab seams after i posted pics of the drivers side in progress. Well lucky for you I am a nice guy willing to help and I still had the passengers side to do. I haven't mudded it yet but you can see the metal work anyway.
I first used a wire brush wheel on my drill to remove the paint and marked the spot welds with a paint pen
I then drilled out the spot welds. This detatches the vertical peice from the cab
I cut the detatched part off with a cutting wheel on a grinder
You never know were rust is hiding
Again I used the grinder with a cutting wheel to cut the rest of the rail off and smoothe everything up with a grinding wheel
For the cab seam the first thing I did was to clean the seam out with a wire brush on my drill
Then I welded the seam...Remember you are trying to fill only. if you get too carried away you will blow A hole in the cab... Especially if you have a rust issue.I would weld a little bit and grind weld a little and grind til it is nice and pretty.
This is the other side that I already mudded
I hope this helps .....
The following users liked this post:
I put my battery all the way in the back. I run a K bottle of compressed nitrogen for my bags so thats what sets on top. You can see the regulator in the pic....Along with the rust soming through the primer lol ...Thats why I have her tore back apart for paint.
I haven't decided how I am going to tackle the door gap issue...My thought was to make a timplate of the shape of the top of the door, transfer that template onto a piece of 16 gauge sheetmetal. Cut it out however wide I need it to be and weld it to the inside of the top of the door. That would add the 1/4 inch or whatever I need to the top of the door to close the gap and I could just use body filler on the outside to make it look good. I DON'T KNOW IF THIS WILL WORK OR LOOK GOOD it was just a thought. As far as your door being racked out of flush thats as simple as adjusting your hinges on the door side.
Yeah I know exactly what you are talking about but i guess I am lucky because mine seem to line up pretty good. I will look at it a little closer now that you brought it up though.
Rocket scientist..NO..but I did stay at a holday inn express last night!
