Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-30-2009, 10:51 AM
Jeremy Ruppert Jeremy Ruppert is offline
Jeremy Ruppert is starting off with a positive reputation.
Do i have the right master cylinder?
I have been trying to get the brakes to work on my 75/79 F250 and i am stumped. The chassis of the truck is a 75 (i think) and has drum brakes all around. I have changed 99% of the brake lines, all four cylinders and have no leaks anywhere. I bench bled the MC and checked to make sure no fluild was leaking out into the booster. I then proceeded to bleed about 400ml of fluid out of each cylinder, starting with the one furthest from the MC.
After all of this i still have a brake pedal that goes almost all the way to the floor before engaging and when it does it feels like only the front brakes grab. I havent tested the brakes at any speeds over 20-30km/hr for fear that i will have no brakes at all. The booster seems to work since there is a noticeable difference when the truck is running.
At this point im thinking i still either have some air in the lines or i have the wrong master cylinder, the MC is from a 79, possibly even a 2WD, that would have been meant for front disc.
Is the MC for front drum alot different or different enough that it may be my problem?? Will a 75 MC fit my 79 booster?
Another puzzling fact is that when i bleed the brakes at any wheel, both resevoirs on the MC go down. I thought the 75 trucks only had a distribution block so im not sure how fluid could be transferring back and forth?
__________________
79 F250 4x4, Lifted, 351M, C6, 9000lb Winch - dirt
95 Mitsubishi Eclipse, Lowered, Turboed - street
06 Kawi KXF 450 - dirt track
01 Ninja ZX6 - street track
92 Arctic Cat Jag 440 - snow
  #2 (permalink)
Old 10-30-2009, 11:15 AM
thekingofcows thekingofcows is offline
thekingofcows is starting off with a positive reputation.
It sounds to me like your brakes are out of adjustment. I know when I tightened the rear brakes on my 79, the pedal got a lot stiffer. There is two ways to do this. The easiest is to put the truck in reverse get going a decent speed and push the brakes in to stop, (it will help to pump up a bit). This allows your automatic adjusters to ratchet and adjust your brakes out a little bit making is so that your brakes don't have to travel as far before they engage the drum. The second method is to take off the rubber plug on the underside of the drum, and tighten them manually with a flat head screwdriver.
  #3 (permalink)
Old 10-30-2009, 11:17 AM
then again it could be the mc. But tightening wouldn't hurt.
  #4 (permalink)
Old 10-30-2009, 11:20 AM
good call, i will try some more adjustment although i did adjust them so that i could hear a light rubbing on the drum at the time of the cylinder replacement. The truck has only seen a few miles since the initial adjustment. The brakes do work a little better in reverse, could this be a sign of needing adjustment?
__________________
  #5 (permalink)
Old 10-30-2009, 11:27 AM
I don't know if the brakes working better in reverse has anything with needing adjusting. But I would adjust them as tight as I could, then back off maybe a1/4 of aturn.
  #6 (permalink)
Old 10-30-2009, 01:33 PM
CrazyAirman's Avatar
CrazyAirman CrazyAirman is offline
CrazyAirman is gaining momentum as a positive member of FTE.
I would try a master for the specific application of your truck....
__________________
I painted the dang thing camoflage, now I cant find it!!
74 F100 4X4 Grump-a-saurass
WAY more guitars than talent
  #7 (permalink)
Old 10-30-2009, 01:54 PM
ya i agree i just wanted to know if there is a real difference between the two before i spend the $60-$100 on a reman. one. I dont want to spend the money only to have the same problem.
Jeremy
__________________
  #8 (permalink)
Old 10-30-2009, 02:02 PM
20.00 for reman.. 50 for a new one. These things are dirt cheap.
__________________
  #9 (permalink)
Old 10-30-2009, 02:08 PM
from who? all i got up here in kaanadda is PartSource and NAPA
__________________
  #10 (permalink)
Old 10-30-2009, 02:13 PM
Shucks/O'Reilly ....
NAPA online shows about 10.00 more for each, respectively...
Didn't see you were in Kanuk land....
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
