no power to fuel gauge sending unit
Old 11-05-2010, 02:10 PM
orich's Avatar
orich
orich is offline
Originally Posted by darknightcrawler
man i cant find a book to help me any weres for this truck of mine its a 1970 ford f100-250 not sure its 4x4 with a 300 straight 6 but i dont know were the orange wire go"s for the fuel gage in my cluster i know its like beating a dead dog but can some plz help me and hell me were this thing go"s my dad told me it go"s up to the cluster that cant be right were in the hell dose the wire go if you now or have a wire digram plz help a bro out lol
Well here it is, the orange gas ga wire looks like it's wire doubles back in the #15 tab on the connector plug that goes into the backside of the instrument gauge panel. 1971 had a flex printed circuit strip on the back side where as earlier had wires going to the gauges itself..Remove plug hook an ohm meter from it to where it connects at sending unit if it shows zip it open some where in between..with key off that is.. my 2cents
orich
Old 11-15-2010, 04:34 PM
BigBlack71's Avatar
BigBlack71
BigBlack71 is offline
I can't figure this out either. I put a brand new sending unit in, so its not the sending unit. The gauge was working at one point but I had no lights at all when I bought the truck and took it to a local shop. They were about to get all my lights working, but the fuel gauge hasnt worked since. Not sure what it could be. I have a tester and I tested the orange wire going to the sending unit and I have nothing. Could this be a fuse? I looked on the woring diagram, but it shows the orange wire going from the sending unit to the "Printed circuit circuit connector" What ever that is. I don't see it going to the back of the cluster anywhere.
Old 11-15-2010, 05:25 PM
orich's Avatar
orich
orich is offline
the orange wire should be going to the plug that plugs into the back side of the dash, I think it's #15 if, I remember right on the plastic plug tab..
The dash lights our the screw in type that make contact with the c-board.
orich
Old 11-15-2010, 05:28 PM
BigBlack71's Avatar
BigBlack71
I inspected the ground wire going to the sending unit and it was barley together. It looks like it was cut and put back together. I touched it and it fell apart. If I repair that wire could that solve my problem?
Old 11-15-2010, 05:41 PM
orich's Avatar
orich
orich is offline
No ground no worky! think about it, why would it have a ground wire if not needed..
orich
Old 11-15-2010, 07:16 PM
dklistul's Avatar
dklistul
dklistul is offline
Let's start over and go back to troubleshooting 101 because I can't seem to make sense of what's been done and what hasn't.
First question: Assuming that you have some gas in the tank, what does the gauge do when you turn on the key? Does it stay on E? Or does it go to F? The answer to this is fundamental to the subsequent troubleshooting path. Further questions to follow after we know the answer to this one.
Old 11-15-2010, 07:18 PM
BigBlack71's Avatar
BigBlack71
When I turn the key its stays on "E".
Old 11-15-2010, 07:49 PM
orich's Avatar
orich
orich is offline
Remove sender an hook up orange wire. Hook up a jumper ground wire to sender. Ok with the key on Hold sender as it would be in tank, slowly move float arm to about center, gauge should move as you move float arm. If no movement. Remove orange wire and touch to ground still with key on. Now gauge should go to full when grounded. if wires and gauge is good.. orich
Old 11-15-2010, 08:04 PM
dklistul's Avatar
dklistul
dklistul is offline
I'm on the road and doing this on my iPhone so if there is any misspelling that I don't catch, please bear with me.
Good. Now we know that there is no current flowing through the circuit. This is NOT a shorted wire; rather, it is an open circuit.
The following simple test will isolate the problem to one of 3 areas: power, gauge or control (tank unit segment).
Test for power on both posts of the fuel gauge. Simply put one test lead to one post of the gauge, the other lead to a good ground. You'll find it may be anywhere between 0 and 12 volts, depending on whether your temp gauge is also operating, because of the voltage regulator unit. Also remember that the "regulator" is really just a betallic switch that turns the 12v on and off, so it generally averages about 12v. Make sure you connect your voltmeter and watch it for several seconds each time to allow for the switching of the regulator. Remember to chech power on both termonals of the gauge.
So here's the next question: Did you find power on both posts, one post, or neither post of the gauge?
(If this is too basic, please say so but I have no idea what your skill level is.)
If you have no voltage on either post, you have a problem with the circuit providing power to the gauge.
If you have voltage on one post but not the other, you have an open circuit in the gauge (bad gauge).
If you have voltage on both posts of the gauge, you have an open circuit between the gauge and the ground after the tank unit.
Post back with the results and we'll work step 3.
Old 11-15-2010, 08:16 PM
dklistul's Avatar
dklistul
dklistul is offline
I meant to say that the regulator switches between 12v and zero volts, to provide an approximate average of 6v, not 12v.
Old 11-16-2010, 10:07 AM
BigBlack71's Avatar
BigBlack71
Okay. I ran a test on the regulator in the back of the cluster. No resistance. I went to a junk yard and took a shot on another cluster. ($30) I tested the regulator on that and got a reading. Switched out the regulators and the gauge works now. A new regulator is 50 bucks through LMC so I guess I didn't do too bad and now I have some extra gauges if I need them.
Old 05-24-2012, 05:10 PM
pedal pusher's Avatar
pedal pusher
pedal pusher is offline
I too am having a problem with no power going to my sending unit.where does the power come from in the truck for it to read the gas
  #28
Old 05-24-2012, 05:11 PM
pedal pusher
By the way i have a 1975 ford f-250 highboy
401tonyo
01-27-2016 01:36 PM
jim collins
10-10-2015 08:25 PM
hoss73ford
08-11-2015 10:47 AM
jrockdiddy
07-23-2015 09:44 AM
FordIowan
06-18-2015 12:39 PM
Quick Reply: no power to fuel gauge sending unit
