what model truck is this from?
That truck belongs to 78_f800crewcab4x4! He's around all the time, hopefully he'll see this and chime in. It can be assumed it's the front end from a '78 Super Duty truck. As for putting one on your F150, it can probably be done if you have the fabrication skills, but I have high doubts that it's very easy. The frames and most measurements would be completely different, I've never seen anyone put those fenders/grill to a light duty truck before.
You could always PM him and ask what was required. Or let him know about this thread so he can come here and tell all us interested people
Ford Truck Enthusiasts Forums - View Profile: 78_f800crewcab4x4
^That`s his profile.
-Jake
-Jake
on
If you are really interested I can give you step-by step instructions. All info, whatever. front end is from a Ford f500-f7000 73-79
There are a lot of things to modify, and several routes to take. I could write 3 paragraphs on this, but I think I need to know what you want your final result to be.
there are two ways to do this mod, the best way and the easy way.
on
essentially, its just modifying the mounts for the body, and a custom mount for the bigger core support. Front clip will bolt on to the cab and look factory, except for some inner fender trimming which I did, and if you have a/c you will need to trim more of the inner fender so it clears the big box on the firewall. I have custom mounts which locate the cabin exactly 6 inches higher, allowing for clearance of the grille and core support at the front of the frame. I suppose you could just lop off the front frame horns and make a drop in the frame to accommodate the difference, but I also needed clearance underneath the whole body for the Rockwell t case, custom fuel tank, and for a dozen other reasons including the ducting for the factory air scoop and possible future installation of a really big diesel.
albertaphotog
08-29-2011 03:30 PM
78_f800crewcab4x4
02-10-2011 12:15 AM
bobj49f2
06-15-2010 02:57 AM
AmeriKen
08-04-2005 03:08 PM
