Pull door panels on 1999 F250 extended cab
This is a great write-up for what you're looking to do; easy job.
Door panel removal
EDIT: The above is just for the front doors. I have a Crew Cab so sorry, I can't help you there.
Door panel removal
Replaced the old head unit with a Sony double din. The stock head unit had the common solder breaking problems. I was able to re-solder and get the display back then the vol. control went out. I gave it one shot at
re-solder with no luck. After an 8 hr trip with little to no tunes, I decided to replace with the Sony head which has all the bells and whistles plus more wattage/amps. That did in the stock speaker in front left. Decided to upgrade them before the other three went out. I purchased four mid-level Pioneer 2-ways, as I don't expect to add an amp. I got the 6X8s as they will match right up to the mounts. The only time I really crank it up is when I have the windows down and need to over power the 7.3 diesel noise. Speakers should be here this week, I should be able to get them in this weekend.
DD
DD
Yes it accepts Sat radio, has a plug for MP3 and best of all a plug for a thumb drive. I put all my favorites on a 4gig thumb drive and can listen to them with no commercials on a small thumb drive that fits in my pocket. No need for CDs and the room they take up.
Speakers came today hope to get them in on Sat.
DD
DD
