Excursion recall
#46
I just have to say THANK YOU for all the posts about the speed cutoff switch recall.
I saw them last night while trying to figure out why my 2001 X cruise light would never come on nor did the cruise control work. I saw the saturated mess all over the wiring harnesses under the master cylinder and couldn't figure out exactly how it got there. I called my local dealer and they had me come in ASAP and about an hour later my cruise control worked (with light) and no more worries about the fire issue.
#47
#50
#51
Nope, you're good on the cruise fix! No BBQ for you. Let me know if its ok with you and I'll post the word doc here or you can pm me your email and I'll send it. BTW, the cam sensor was done too.
#52
Stewart
#54
The way I found out that I needed to do the recall fix was by going to the Ford web site and clicking on the safety recall link under ownership on the bottom of the page. My wife called the next day to the local dealership and they said to get it in by 11. There was no charge and they changed the sensor that goes into the master cylinder and added a short wiring harness the has a fusable link in it. The original system had no fuse to pop to cut power if (more like when) the switch shorted from the brake fluid leaking all over it.
BoydII
1999 to 2016 Super Duty
10-24-2014 06:56 PM
UrbanXX
07-04-2009 06:59 PM
