Axle swap F250-EXcursion
Jeff, I tried looking the specs up for you, but I'm having problems with the site.
Go here:
https://www.fleet.ford.com/truckbbas.../techspec.html
And look up the axle specs between an '02 Ex and '02 F250. For some reason the '03 Ex isn't available here, but the specs should be the same. I think it'll work just fine but I'm not sure of that.
If it comes down to it, get down there and measure them!
Go here:
How are you going to get the speedo and shift points right, dealer reflash or tuner?
Tell us how it goes and what the MPGs do, I am wanting to do his swap on my V10 E350.
IF it ever happens I'm hoping my Diablo tuner will be of some help. Right now it's just a pipe dream...
When changing out just the gears, no speedo adjustment required. I went from 3.73 to 4.30 and speedo is perfect. I do use a SuperTuner to change shift points for towing, but it is not required. If the rearend from the Ex does match up, you'll be pleased with it. It really helps with the get up and go, but not much on the "sustained" towing (in other words, it'll still gear hunt on hills, just now quite as much).
JeffsLightning
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
12-16-1999 04:23 PM
