1996 E4OD solenoid block in older E4OD transmission
Old 10-11-2009, 07:26 PM
Hilux's Avatar
Hilux
Hilux is offline
Will a solenoid block from a 1996 E4OD transmission work on an older E4OD transmission ? the junk yard sold me an older pre 95 E4OD trans and the solenoid block connector is different on the 95 and 96 trucks so now I am wondering if I can just change out blocks .
Old 10-11-2009, 07:34 PM
Race4Fun's Avatar
Race4Fun
Race4Fun is offline
I have the same situation I got the plug off the older donor truck and spliced it into my wiring harness. The truck backed out of shop and then went a few feet & now won't move. See my post 95 to 93 E40D swap. I think you may need to put the newer block in. Can Anyone help this guy and possibly me to.
Old 10-11-2009, 08:02 PM
Hilux's Avatar
Hilux
Hilux is offline
I am about to say screw it and just put my 5 speed in it I have laying around from my 93 Ford project . all I should need then is a computer .
Old 10-11-2009, 09:32 PM
95F350XL's Avatar
95F350XL
95F350XL is offline
I put in a 90 E4OD into my 95 F350, and I used my selonid pack from the 95 trans. The 90's 1 was different, and had different plugs in it. Just swap whatever pack you need into the trans. Its all the same valve body and such. Mine been good for 2 years now. Put a shift kit in while your at it, makes the trans so much better then the slow, sloppy, shiftin trans come alive.
Also had to change the switch and linkage on the trans, was also different.
Old 10-11-2009, 09:39 PM
LCAM-01XA's Avatar
LCAM-01XA
LCAM-01XA is offline
Hilux, it is my understanding that the reason for the different connectors is so that you can't swap the solenoid packs easy, IIRC in the earlier setups the circuit protections are built into the solenoid pack, and the newer style the protections are in the ECM - if you put in a new-style pack with an old-style ECM you will have no circuit protections and you may fry something. I do believe tho the opening in the trans case is the same, in which case you should be able to just put in your new solenoid pack in the older-style trans, but there may be some check ***** above the separator plate that should not be there for the new-style pack to work... I'm thinking we need to get Mark Kowalsky to shed some light on this sunject.
Old 10-11-2009, 09:54 PM
95F350XL's Avatar
95F350XL
95F350XL is offline
As I said in my post, I put a 95 pack into a 90 trans, and it works just fine, the ck ***** are in the same spot on the 90 and 95 trans. All the parts are the same, the case, main valve body, and the accumulator valve body.
Old 10-12-2009, 03:11 PM
Hilux's Avatar
Hilux
Hilux is offline
I just ordered a refurbished solenoid block from NAPA it should be here in a day or two .
Old 10-12-2009, 03:31 PM
linckeil's Avatar
linckeil
linckeil is offline
the e4od has seen many upgrades since its introduction in 1989 right through the 1995 model year. for a good introduction, read this:
An Introduction to the E4OD Transmission - Baumann Electronic Controls, LLC
Old 10-12-2009, 04:38 PM
doom899's Avatar
doom899
doom899 is offline
How did you make the speedometer work from the mechanical 90 to the digital 96? I have a chance to get a 96 tranny for my 90 but the speedometer would have to go from digital to mechanical, unless the mechanical can be converted?
Scndsin
19
02-06-2019 11:48 AM
Jmitich
16
01-16-2016 09:02 PM
AF_MAC
07-05-2014 06:45 PM
omanalansan
23
12-08-2011 08:14 PM
Hilux
10-10-2009 10:24 PM
Quick Reply: 1996 E4OD solenoid block in older E4OD transmission
