Alberta Chapter Join Chapter, Leader: Puddy
Phosphoric acid
Old 08-19-2002, 12:20 PM
75crew's Avatar
75crew
75crew is offline
Phosphoric acid
If I am reading everything correctly, it seems that most rust convertors (metal ready, prep etc.) are just phosphoric acid. Any idea where to buy this product in the Calgary area? Can you just paint following the application? Thanks.
Old 08-25-2002, 10:16 PM
Drexx's Avatar
Drexx
Drexx is offline
Phosphoric acid
Been in the body business over 6 yrs now and have used all types of rust converters or cover over items, none of them work long term.
Bottom line nothing works like a good spot(sand) blaster and some epoxy primer.
Make sure to sand blast all the rusty area, then apply epoxy primer to the bare metal. Once the epoxy primer is dry then you can fill or fibre glass any of these areas.
Old 08-25-2002, 11:16 PM
trinogt's Avatar
trinogt
trinogt is offline
Phosphoric acid
DickNitro
03-06-2019 12:26 AM
DPDISXR4Ti
02-27-2017 05:49 PM
timbersteel
06-16-2016 08:56 PM
Armalite
Paint & Bodywork
03-03-2013 10:29 PM
big wind
Paint & Bodywork
11-30-2004 12:57 AM
Quick Reply: Phosphoric acid
