Phosphoric Acid. Quick question.
I have it sitting on the panel now and have been applying new coats every couple hours. Google search really didn't give me a definite answer.
Here's a link I found very useful when treating my new-to-me '03 E250 floor: POR-15 APPLICATION
HTH
HTH
Is it okay to let the phosphoric acid dry to that white power while waiting? Then clean it off and reapply it wet for about a hour before the por15?
Basically I need to know how do and if I have to neutilize this stuff before the por15. Just clean it off with water and dry it? Do I need soapy water, water with a bit of baking soda?
Heres a little insight on what im doing.
-89-97 f series bed (besides 97 f150).
-These beds are known the rot out above the wheel wells.
-Got a southern rust "free bed". Note: none of these beds are rust free. Unless it was kept in a climate controls area with no dust or moisture.
-These beds are knwon to rot between the inner and outer wheel well panels.
Heres what im doing.
- Drilled all the spot welds and removed the inner fender from the lip and inner bed skin.
- Bed was rust free from tenn.
- But there was rust starting on the outer panel from the inside. Just small pitting and some scaling. Nothing came through to the outside. Basically all these beds no matter how clean they are have rust. Aslong as there dust, salt in the air and it gets up behind that fender. Also the middle stake post allows water, dirt and what ever to go straight down there. Moisture also gets up there from the air and has no place to go.
- So you basically take that inner fender out. Clean up all the rust and hope there are no pineholes while sand blasting. And apply por15/or epoxy primer... Drill wholes in the inner fender and reattach it using 3m adhesive. Note 3m needs bare metal to bond. So leaving the lip and the areas on the inner skin bare .
- The panel adhesive also will seal off oxygen and moisture to the bare metal. and it will give the area between where it meets at the lip and nice waterproof seem. The holes allow dirt and what ever to come out. Allowing you to clean up there with a hose and what not. Here are some pictures."
Heres a picture of a inner fender removed and the drain wholes drilled.
Heres a picture of the inner fender with holes back inplace to show how you can clean the area.
Heres a picture of the inside outer panel. All rust is sandblasted and the panel is being etched for por15. Still looking on how to property clean it for the por.
I wont be re-installing the inner fender till the bed has some body work and paint done. Leaving it out for now makes it easier to work on. But I will be taking pictures of the whole process and hope to have a write up sometime in the future. This is basically saving one of these beds from rotting out. Also leaving a inner fender out will cause the bed to do alot of twisting while driving lol. It will also allow rocks and stuff to be thrown up and possible put a dent in the beside. It should be re-installed. But with drain wholes and glued in. Not welded.
After allowing the etch material to work and rinsing it away as suggested I let the van sit until it was completely dry, probably almost 24 hours. (I was doing everything outside, during the summer.) Applied the first coat with a small roller waited about 3 hours then applied the second coat.
I don't know I'd etch and rinse any parts and wait a significant time later to apply the actual POR-15. Its possible air-borne crap would land on your prepped pieces and reduce the coating's ability to properly bond to the bare metal. I paid close attention to this from the link I provded:
If you waited longer that 24 hours to apply a top coat TIE-COAT PRIMER or ETCHING PRIMER required.
On another note I know budget is important but going through all this effort and using another brand etch material seems a bit self defeating. A one time expense of $40 is a bit small compared to the time, effort and expense you're already incurring. Just my thoughts----------I'm sure this will work just fine for you.
Looking forward to your updates too!
Sorry if I'm not being all that helpful. I based my process on more experience hands who use POR-15 somewhat regularly as well as their suggested methods.
What I might do for the time being is just clean the area and primer/basecoat it intill it gets warmer out and after the body work is done. Then resand and etch it and apply por.
And why the advice against POR-15?
Interesting thread so far!
As for the POR . it fails. Its a hard surface, but adhesion can fail. I like using a true primer. It's a moisture cured primer, but it can be applied over good metal or rusty metal ( unlike POR ). If you want to use POR as a topcoat, go for it. But don't use it as the base, just my opinion. I've been using Master Series for 17 year or so?? It is a material to use as a primer, then top coat as you want. You could use it to remove the pits,sand, then epoxy over that. I use in on pitted panels. I have used on tops of cars that had a vinyl top. Extremely pitted. Those cars I did this on still look the same today, many years later.
I plan on sanding the primer off to bare metal again and reapply the acid then por15 once it gets warmer.
But why do you suggest not rinsing the acid off before primer/paint? Like I said above. Once this area is painted and the inner fender is re-installed with adhesive there is no way to get back there.
Surface prep along with assuring the best avenue for adhesion is paramount in any material applied to an auto/truck body---that's been constant since my body shop ownership days back in the 80's.
For my money and a relative ease of application POR has a lot of fans and followers.
Just my $0.02 worth ya know!
