Exhaust fumes in cab
Old 10-10-2009, 11:11 PM
CruiserClass's Avatar
CruiserClass
CruiserClass is offline
Today I noticed I'm getting some exhaust smell in the cab while I'm sitting still. Tomorrow I'm going to make sure all the exhaust clamps are tight in the engine compartment and see if there's any obvious leaks.
Anything else in particular I should be looking for?
Old 10-10-2009, 11:17 PM
pbr man's Avatar
pbr man
pbr man is offline
It is probably the up pipes to the turbo. The factory pipes tend to leak. The best solution is the new bellowed pipes.
Mine gets some exhaust in the cab when it is cold. I have the bellowed up pipes from Riff Raff Diesel Performance setting on the shelf waiting to "drop in".
mueckster's Avatar
mueckster
mueckster is offline
Look for soot at the uppipe joints of the Y collector at the back of the turbo. The donut gaskets are notorious for leaking there. I used to smell exhaust upon start up when mine were leaking.
EDIT: Like said ^^^ IH bellowed uppipes are the best solution to this problem.
Old 10-10-2009, 11:18 PM
pbr man's Avatar
pbr man
pbr man is offline
Some how it double posted.
Old 10-11-2009, 05:38 PM
CruiserClass
Wow. Those bellowed pipes appear to be rather pricey. I'll probably have this truck for most of eternity, but I drive it about 5k miles a year or less. I might go with the factory set up for the time being.
Didn't those bellowed pipes used to sell for $300 or so fairly recently? Ouch.
Old 10-11-2009, 06:51 PM
crazymut's Avatar
crazymut
crazymut is offline
Most likely you will still need new up pipes and the doughnut seals. Might as well go with the bellowed pipes. Usualy the stock pipes, if leaking, are shot when you take them apart.
Old 10-11-2009, 08:41 PM
mueckster's Avatar
mueckster
I put the factory stuff back on the first time I did this. New donuts pipes, flanges, bolts, and all. I even put a new Y collector on too due to a broken bolt I couldn't get out. 1 1/2 yrs later I was putting on the bellowed uppipes when I was installing my 38R. The factory pipes were already eroded at the donuts and leaking. I won't have to worry about that anymore.
Old 10-24-2009, 03:32 PM
CruiserClass
Finally got around to looking at it today and I got off cheap. Looks like it was just the clamps had stretched and were leaking at the Y tube that goes to the turbo cooler. Tightened them up and cleaned up the soot, then drove around a bit and it seemed to fix the proble. I'll see if the soot comes back, but way better than having to mess with the up pipes.
DmanNC
03-01-2014 07:18 PM
nolanb
12-02-2012 09:18 PM
Jarhead97
10-11-2012 07:30 AM
Patton531
07-22-2011 03:23 PM
bramakril
1999 to 2016 Super Duty
02-17-2009 08:09 PM
Quick Reply: Exhaust fumes in cab
