aliddlebit of a rough idle
10-06-2009, 09:24 AM
on
when im stopped my rpms dip down a little bit too far causing the truck to shake,
what are some things i should look into?
thank you
10-06-2009, 10:54 AM
It sounds like you have a miss at idle, or at low RPM.
I would check out the following:
1. Idle Air Controller
2. Coil on Plugs (COP's)
3. Bad spark plug
4. MAF
5. Throttle Position Sensor
It's likely the IAS or COP though. We would need a little more info though.
10-06-2009, 11:21 AM
on
thanx mike!
ill try a few things
10-06-2009, 11:28 AM
Quote:
Originally Posted by
MikeMcCasland
There is no IAC on the 3V modulars.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
