5-speed in 93 lighning
Bell, clutch, trans, crossmember, possibly driveshaft work, pedals, clutch set up either cable or hydraulic, shifter set up, speedo drive set up.
Ford truck 5 speeds would be a miserable and short-lived choice, so you are looking at a TKO or T56.
TTC: TREMEC Transmissions
Modern Driveline - T5 / TREMEC TKO Transmission Conversion - 5 speed & 6 speed solutions to swap your Ford Mustang, Falcon, Cobra, Hotrod into Overdrive! Performance Parts
Rockland Standard Gear Manual Transmissions
No you can't take a T5 out of a Mustang and expect it to live in this application.
The Mazda 5 speed would have OK ratios for this application, but probably wouldn't last long. The ZF would probably take the power, but really, you want a granny first gear trans in a sport truck?
Go find one to drive and sample the ratio spread and shift quality before you saddle yourself with one.
I agree. A manual would be more fun but your options leave much to be desired.
Your year Ford F-150 came from the factory with either a 3.08 or 3.55 gear ratio. Look at the paper sticker tag on the inside of your door and read us the axle code. Or, crawl underneath your truck and look for a metal tag on a bolt on your differential cover.
