Ford Truck Enthusiasts Forums
-   Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 (https://www.ford-trucks.com/forums/forum26/)
-   -   5-speed in 93 lighning (https://www.ford-trucks.com/forums/889944-5-speed-in-93-lighning.html)
3-fords 10-04-2009 09:58 AM
Im selling my mustang and 65 f 100 to buy gen 1 lightning but i want a 5-speed. What would I need to do to make this happen?
85e150 10-04-2009 12:14 PM
Bell, clutch, trans, crossmember, possibly driveshaft work, pedals, clutch set up either cable or hydraulic, shifter set up, speedo drive set up.
Ford truck 5 speeds would be a miserable and short-lived choice, so you are looking at a TKO or T56.
TTC: TREMEC Transmissions
Modern Driveline - T5 / TREMEC TKO Transmission Conversion - 5 speed & 6 speed solutions to swap your Ford Mustang, Falcon, Cobra, Hotrod into Overdrive! Performance Parts
Rockland Standard Gear Manual Transmissions
No you can't take a T5 out of a Mustang and expect it to live in this application.
3-fords 10-05-2009 06:27 AM
I know a T-5 is no good. I was looking at getting the parts from a truck at pull a part.
85e150 10-05-2009 01:05 PM
The Mazda 5 speed would have OK ratios for this application, but probably wouldn't last long. The ZF would probably take the power, but really, you want a granny first gear trans in a sport truck?
Go find one to drive and sample the ratio spread and shift quality before you saddle yourself with one.
Blurry94 10-09-2009 09:15 PM
A granny gear isn't neccessary in a single cab/short bed 2wd truck with a 351 and 4.10 gears.
92f150I6 10-10-2009 08:07 PM
You could try to do a toploader 4 speed, but you wont have an overdrive.
TexasGuy001 10-11-2009 04:13 AM
Personally, I would leave it with the E40D.
Jason Lewis 10-11-2009 12:53 PM
NLOC Post !
5-speed Conversion Complete (long...lots of pics) - The National Lightning Owners Club Inc
85e150 10-11-2009 05:25 PM
Well over $2000. Maybe a Clark.....}>
96 ford f150 10-13-2009 08:24 PM
hey im new to fords what rear end gear does a 96 ford f150 with the 300 inline 6 have it all stock
93F22A6 10-15-2009 08:12 PM
I'm just curious as to why the T-5 is no good. What other 5 speed options (stock wise not looking to spend a lot of money)? (I have a 76 F-100)
96 ford f150 10-15-2009 11:10 PM
does any body know what gear i have in my rear end ive heard i had 4.11 rear end but im not sure it is stock and i think it is a 2.73 which is it
6CylBill 10-17-2009 05:42 PM
I agree. :D A manual would be more fun but your options leave much to be desired.
Your year Ford F-150 came from the factory with either a 3.08 or 3.55 gear ratio. Look at the paper sticker tag on the inside of your door and read us the axle code. Or, crawl underneath your truck and look for a metal tag on a bolt on your differential cover.
96 ford f150 10-18-2009 12:54 AM
ok ill do both
96 ford f150 10-18-2009 01:00 AM
ok it say axle 17
