magnaflow y pipe
magnaflow y pipe
Anyone use this piece?
i am curious about the tube diameters, i am unable to find anything about it, i cannot tell if this is a stock sized replacement, or if it is like the bassani 2.5 in downpipe, 3" outlet.
at half the price, i would like to use the magnaflow, but i want the size of the bassani.
this is the bassani: Bassani Y Pipe
and the magnaflow: MagnaFlow 93312 - MagnaFlow Direct-Fit Catalytic Converters - Overview - SummitRacing.com
the magnaflow states 2.5" inlet, and 2.25" outlet, which makes no sense to me.
I have never personally used either of those. one of my good friends on the other hand, had a 302 with the magnaflow on it for a while. it sounded pretty good and had a decent power gain over stock. He got bored with it after a while and got true duals, magnaflow high flow cats and universal 1-in-1-out mufflers. it sounded amazing and there was mild but noticeable power gain over the Y pipe. the whole system at a muffler shop cost him a little less than $400 (pipe, cats, mufflers and tips)...just my 2 cents
The descriptions at that site are awful. No wonder it is so confusing. I used a Bassani 58150B2 on my '92 F350 w/351W. It is the off road version. Then I used a Magnaflow 59929 converter. The Y-pipe necks up to 3" right after the junction of the manifold down pipes. On a 351W I think those are 2.5". It is a very nice piece. The Spun Series converter is rated for up to 6.2L engines and test weight of 6000 lbs. The cat is very compact with a metallic core.
The Magnaflow 93312 is designed to fit the OEM sized pipes after the converter, therefore the reason for the restrictive 2.25" after-cat pipe size. Not the best setup IMHO. The Magnaflow Y-pipe w/CAT is CARB legal, it may the best way to go as far as performance gain. I was concerned of the rating for the converter due to my 8800 lbs. GVW on my F350. That is why I opted for the B2 version with my choice of converter.
can't speak to the magnaflow, but i got the bassani pipe with cat for my 1996 F350 with 351. here's a couple of pics i took a while back comparing the stock pipe to the bassani pipe. fit and finish are great, and its stainless. i got it to my door for under $400. not cheap, but it'll last forever. i don't regret spending the extra bucks for the bassani unit. you can see the o2 sensor is in a different location as the bassani is designed for an f150/bronco.
http://www.plowsite.com/showthread.php?t=83211
As long as you use a shorty header designed for a Ford truck any of the listed y-pipes without the need for a trip to the exhaust shop. I was short on cash so I stuck with the stock designed manifolds for my install.
Feardeere7
03-05-2015 04:59 PM
bwigfield
01-25-2012 10:51 AM
