check engine light goes on under load????
Then on the top line of this forum page you will see Tech Info right next to "Read First" in red, click on that and then on OBD1 self test for instructions on getting the trouble codes using the blinks of the check engine light.
This way the computer can sometimes tell you what is wrong and saves throwing parts at it.
my 7.3 excursion does it with a load or slamming on the throttle. If you find out anything please let me know.
on
Your timing isn't set right or you have an excessive amount of carbon buildup on the piston crowns. What is your timing set at right now?
Sweetrocks
Modular V8 (4.6L, 5.4L)
48
04-25-2018 12:06 PM
MurrietaBigMike
08-01-2016 04:45 PM
Richardson
15
09-21-2004 01:19 PM
