EFI or carbureted?
EFI or carbureted?
I've got a 1995 f150 4.9 EFI. It has over 190,000 miles on it and i have been doing some minor tune up stuff on it. i would like to get a little more power out of it. i already have K&N intake and new magnaflow exhaust. i was hoping to get new headers soon. but i was curious about the intake and fuel system. would it be logical to convert it to a full carbureted system? I used to have a 66 bronco with a carb 351 in it and i loved how easy it was to work on and tune. any suggestions are greatly appreciated.
thanks,
A1C DiMaggio
thanks,
A1C DiMaggio
I also had a '95 4.9L 4x4 truck with 2 times the miles on it. There are some things you can do to coax more power out of her, but it's not "surprizing" gains.
I had several mods done on mine and I'll list them below. The combination of them all worked quite well.
1. Comp cams 268H cam.
2. Walker downpipe.
3. New cat. (circa '95 cats are craaaaaap. Install a new universal one, they flow much better than the stocker ever did.)
4. Summit 3" single cat-back exhaust with welded muffler.
5. 351w throttle body and porting done to intake to match TB to it.
Oh yea, thanks for your service. I'm a USAF rescue veteran.
2. Walker downpipe.
on
Also, 19lbs injectors and adjustable fuel pressure regulator from a 5.0. It will require a custom 3-pointed mounting bracket, easily made- you'll see when you compare the new one to the old.
+1 on the cat. Look at how the exhaust crushes down near the stock cat. The stock stainless Y-pipe is good (gut the pre-cat & use it as a 2.5" collector).
"cheap" cam option is to substitute BBC 1.7 ratio rockers. $USD2 each and they bolt right on.
'95 computer can't handle really radical mods. If you keep it at the list discussed so far, you should be OK.
It is going to depend on whether or not you want to get a little more power out of it, or a lot more power out of it.
If it's a little more power, what was mentioned above will liven your motor up and give you a bit of extra go.
If it's a lot more power, you'll have to either put in a new fuel computer like a megasquirt system, or convert to carbureted. The carbureted would be the simplest and less expensive of the two endeavors if power is your goal.
on
thanks,
A1C DiMaggio
thanks,
A1C DiMaggio
You have 190000 miles on it, and you want to build it now??
OK. I would say. Start with a rebuild at this point LOL
Before you go dumping money into your engine, you might consider checking the compression, even if it is good. The only reason it stays running good is because the fuel injection, is contantly adjusting the fuel, and ignition. Fuel injection is definatly better the carburation, as far a drivability goes. But you also need to understand it, to diagnose any problems when they arise.
I had the same truck 4.9 with a 5 speed. It ran way over 300000 miles, but in order to get alot of power, your gonna need to wind that engine up. With those miles. You aint gonna wind it up to many times. before the gerbils go on strike...
That is why you only got 400 hp. My advice is loosen the wing nut, and slide a windsor under it, then you can make more HP. 400 is child play
Watch the vid in my sig... 351 windsor, and a small block chevy. Hear his engine, then hear mine...LOL
p.s. like the gerbils line
Dude, my 350 is mostly bone stock. I can drop a couple G's and blow the doors off your pathetic little rigs.
