I need to replace the factory 6 disc on my wife's 02 Explorer Eddie Bauer. The manual shows the same picture for the standard 6 disc and the 6 disc with amp and sub.
The plugs in the back should be a dead give away. Without should only use one 16 pin harness, if you have a factory amp then there will also be a 4-8wire harness.
