front differental won't come out?
Ok, I'm no dummy, I've done this before just not on this truck. 95 f350. I removed the axles from the front and unbolted the bearing caps on the diff gear. Then I proceed to ply,hammer,and even hook a strap around the diff gear and try to ratchet it out, but still no good. This thing is stuck in there. Am I missing something? Help!
It actually sounds like it was set up properly. Dana's require a housing spreader to set the gears up correctly. That's what the two holes on either side of the diff cover are for. Only option is to come up with a better pry bar, or get a housing/case spreader. I had one like you have before. I took the axle out, put it on jack stands. Then took an engine hoist, placed the legs OVER the axle tubes, wrapped a chain around the carrier. I pulled the hoist to a dead stop on the 2k setting. MAJOR, MAJOR tension on it. Tapped it with a ball peen hammer and the diff flew out of there with enough force to knock a hole in the roof of the shop, then took a nice chunk of concrete when it came down. DO NOT DO THAT!!! lol Good luck man, some are harder than others.
jadmt
11-12-2008 02:44 PM
horndwg
06-19-2003 11:42 AM
