Gonna turn rotors on my 2007 2wd.... I there any tricks to put new pads and repacking the wheel bearings on the front ???
Did a search and there's no good instructions
So you're saying that these rotors are a sealed unit and that repacking is NOT an option... I just want to take them for their first turning and put the new pads on.
getting ready to do this... Can they be taken off and carried in for someone with a rotor laith or do they have to be done on the vehicle with a "onthe Truck" laith ???
On my 93 bronco, the brake disc and ring appears one piece with the hub, but only the wheel studs hold them together as a unit and when the studs are driven out, they separate. NBD to remove and reinstall the studs.
I havnt looked at the 07's, but are they similar or are they actually cast as one piece?
