I am looking at a '99 F250LD. I am trying to figure the axle ratio. The code on the door sticker is Axle 8 Ratio B6 What does that translate to? Thanks.
If you are unsure of the code, or to check to make sure look at the diff. cover. there will be a tag attached to one of the bolts. it will tell you if it's still readable.
the 250LD had 10.25" rear ends where the f150's had 9.75".
Thanks guys. I see by the transmission code that there is a 4R100hd trans. Is that what the 250LD had? From other posts I have seen in the past it was different from the normal F150.
