about the front wheel bearings for a 2003 f-250 4x4 manual locking hubs?
There are no standard, servicable wheel bearings like on your old truck. The wheel bearings are contained in a sealed wheel bearing/hub unit. This bearing hub is available locally, etc.
The link Brian gave is to re-pack/replace a needle bearing that sits in that bearing hub --- it is not a wheel bearing, but only a bearing to support the axle end.
Good luck.
Good luck.
If you really want to grease the MAIN wheel bearings, not just the stub axle needle bearings, here's a link:
https://www.ford-trucks.com/forums/8...pics-here.html
However, if the bearings are already starting to go, this procedure won't be of much long-term value. It's a preventive-maintenance item, not a "fix".
Pop
Pop
Depending on the dealership, it could be more or less (probably not less). Some dealerships have more of a markup above MSRP than others. I was able to get my hubs through my "regular" parts guys for about $250/each (I replaced both my front hub assemblies recently).
I'm not sure what shipping would be (they are not light), but you can try Ed to see what he can do for you. Here's his site:
http://www.trademotion.com/partlocat...?siteid=214072
If you have any questions there are allot of options with these trucks such as 4x4 vrs non 4x4, 4 wheel or 2 wheel ABS, single or dual rear wheel etc.,some models have five different hub choices they could have came with depending on the options package.
I can help you weed through it if you need help.
Tony
F-Series Ford Truck Hub Assemblies
airsoft1779
28
12-12-2012 10:09 PM
jackyoung
06-07-2011 01:45 PM
BDFD
04-08-2010 01:26 PM
