1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Do you need a commerical liscense.....
Old 08-21-2009, 08:37 PM
jac08f250's Avatar
jac08f250
jac08f250 is offline
to drive a f-550?
Old 08-21-2009, 09:22 PM
Tom's Avatar
Tom
Tom is online now
No.
Max GVW for an F-550 is 19,000 lbs, which is under the 26,000 lb limit. You can drive it with a regular license.
The exception here is if you are towing a trailer that would put the max gross weight over 26,000 lbs. For example, if you are towing a trailer with a 10,000 lb weight rating, you technically would have to have a CDL.
Also, if you are hauling a placarded amount of Hazmat...but that's another matter altogether.
Old 08-21-2009, 10:13 PM
jac08f250's Avatar
jac08f250
That's good to know. Might have to get one for my next truck.
Old 08-21-2009, 10:20 PM
chester8420's Avatar
chester8420
chester8420 is offline
No you don't. (CDL stands for "commercial drivers lisence") You are not required to have a CDL with any kind of truck unless you are hauling commercially. I have been driving a 2005 Freightliner classic XL w/475 twinscrew CAT @ 80,000+lbs all day and I don't have a CDL! Here's a pic of my truck.
Old 08-22-2009, 01:30 AM
Pinky Demon's Avatar
Pinky Demon
Pinky Demon is offline
My *** you don't. What the second poster said about the GVWR is true.
Old 08-22-2009, 01:52 AM
TexasRebel's Avatar
TexasRebel
TexasRebel is offline
Can anyone say Ag. Exemption?
Federal law says, if your tow vehicle has a GVWR of 10,000 or more and the sum of your truck and trailer GVWR is 26,000 or more... a CDL is required...
with some exemptions for recreational vehicles, and ag setups.
Old 08-22-2009, 05:28 AM
senix's Avatar
senix
senix is offline
Received 1,418 Likes on 1,013 Posts
Farm is generally exempt.
Even here in MD if you go over 26K gotta get the CDL. I think that is standard in every state that I have checked into.
Old 08-22-2009, 06:59 AM
CampD's Avatar
CampD
CampD is offline
First requirement of a CDL license is airbrake certification. You drive that rig on the interstate with your "regular license"and go thru a weigh station shes gona be parked and your gona be walkin
Old 08-22-2009, 07:11 AM
Tom's Avatar
Tom
Tom is online now
That's great! Very misleading, Chester!
There are some exemptions, such as agricultural and RVs. But many times that varies by state law, and as soon as you do cross state lines you engage in "interstate commerce", in which case I believe exemptions do not apply. Just try and drive that across state lines!
Back to the OP again...
To be honest, I don't think I'd want an F550. I bought my F250 to tow my trailer, which has a GVW of 10,000 lbs. With my "little" F250, I can drag that thing around anywhere I want, without a problem. If I were to tow my trailer with an F550, it'd technically require a CDL unless it met one of the exemptions like Chester pointed out. I do have a Class A CDL, but I think you need commercial insurance and registration. I don't think you need operating authority or a DOT# if you're not a motor carrier, but I'm not sure...
Opens a lot of problems when you break 26,000 lbs...I wouldn't!
Old 08-22-2009, 04:35 PM
TexasRebel's Avatar
TexasRebel
My '08 F250 has a GVWR of 8,800#
being a single cab I have a max cargo + passenger weight of 2,918#
I weigh 180#, and allowing for fuel and equpiment I won't drive far without, we'll call it 2,500#
So technically, I can have a pin weight of 2,500# (RAWR is 5,892#)...which puts a properly loaded trailer (15% weight on tounge) at just over 16,500# with 14,000# on the trailer axles
However! I could hitch up a 20,000# GVWR trailer (28,800# combination) and not need a CDL, since the tow vehicle is less than 10,000# GVWR
Old 08-22-2009, 05:14 PM
RACERX7775's Avatar
RACERX7775
RACERX7775 is offline
I dont know about all other states but here in pennsylvania, which I have a class A CDL, a vehicle with a weight of 26000# or less and towing a 10000# or less trailer only requires a class c license. when you step over the 26001# to 80000# straight truck and towing 10000# or less, you need a class B. the last difference being driving any vehicle greater than 26001# AND towing more than 10000# is where you NEED a class A license. THATS THE LAW IN PA. I WOULDNT TRY AND DARE TO DO OTHERWISE. YOU WILL RISK THOUSANDS OF $$$ IN FINES... AND HAVING THE TRUCK TOWED. CDL does mean commercial drivers license but just because you aren't driving a "commercial" vehicle, doesn't mean you don't need a CDL. and i am talking all gvw's. and I know that you will need an air brake endorsement for a tractor trailer. I have never seen a heavy truck of 80000#gvw without air brakes.
Old 08-22-2009, 05:26 PM
TexasRebel's Avatar
TexasRebel
you don't need a CDL or air-brake endorsement to drive a Semi from farm to market in some states
ftp://ftp.txdps.state.tx.us/forms/cdl-2.pdf
Old 08-22-2009, 05:29 PM
Tom's Avatar
Tom
Tom is online now
Good info, I don't know the specifics in PA, but I thought all vehicles and combinations over 26,000 required a CDL.
Either way, the air brake endorsement is not required if the truck doesn't require a CDL. For example, a straight truck with a 25,000 lb GVW that has air brakes can still be driven with a regular license. A truck with a 30,000 lb GVW with air brakes will require both a class B CDL AND an air brake endorsement.
Old 08-22-2009, 05:45 PM
RACERX7775's Avatar
RACERX7775
Correct. When you break the 26000 pound barrier is when you need a cdl.
Old 08-22-2009, 05:55 PM
TexasRebel's Avatar
TexasRebel
FMCSA §383.91 Commercial motor vehicle groups. (a) Vehicle group descriptions. Each driver applicant must possess and be tested on his/her knowledge and skills, described in subpart G of this part, for the commercial motor vehicle group(s) for which he/she desires a CDL. The commercial motor vehicle groups are as follows:
(a)(1) Combination vehicle (Group A)—Any combination of vehicles with a gross combination weight rating (GCWR) of 11,794 kilograms or more (26,001 pounds or more) provided the GVWR of the vehicle(s) being towed is in excess of 4,536 kilograms (10,000 pounds).
(a)(2) Heavy Straight Vehicle (Group B)—Any single vehicle with a GVWR of 11,794 kilograms or more (26,001 pounds or more), or any such vehicle towing a vehicle not in excess of 4,536 kilograms (10,000 pounds) GVWR.
(a)(3) Small Vehicle (Group C)—Any single vehicle, or combination of vehicles, that meets neither the definition of Group A nor that of Group B as contained in this section, but that either is designed to transport 16 or more passengers including the driver, or is used in the transportation of materials found to be hazardous for the purposes of the Hazardous Materials Transportation Act and which require the motor vehicle to be placarded under the Hazardous Materials Regulations (49 CFR part 172, subpart F).
it has been posted here before, but here is the federal definition of the commercial vehicle groups...
group 1 is a combination of vehicles that has a GCWR of more than 26,000# in which the vehicle being towed has a GVWR of no greater than 10,000#
For example, a truck with a 25,000# GVWR could pull a trailer with a 9,000# GVWR, weigh in at 34,000# and not need a CDL.
Quick Reply: Do you need a commerical liscense.....
