Window channel before or after paint?
Old 08-20-2009, 11:36 PM
keith56_cruz_cab's Avatar
keith56_cruz_cab
keith56_cruz_cab is offline
I need all new window channel / guides in the doors.
The truck is still in primer but I'm thinkin I should Install
these now before paint because I'm afraid of scratching
the good paint. Good or bad idea?
Old 08-21-2009, 12:04 AM
seaves46's Avatar
seaves46
seaves46 is online now
Bad idea , do them after paint as you will be able to get paint in there better and a much nicer job , also you won't have to mask them up and worry about painting them .
Old 08-21-2009, 12:27 AM
Julies Cool F1's Avatar
Julies Cool F1
Julies Cool F1 is offline
Paint first. But let it dry for a good two or three weeks before working around it.
Old 08-24-2009, 09:14 AM
fiftysixfordf250's Avatar
fiftysixfordf250
fiftysixfordf250 is offline
I would paint it first, let it dry for a couple weeks and then apply masking tape over the paint where you are working. The tape will protect the paint from scratches. Just remove the tape slowly and gently when you are done. I have done this a few times and it works great.
Old 08-24-2009, 09:30 AM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
I would definately cut and fit all your channels and glass BEFORE you paint! I just went thru this........trying to fit after painting, not good. plus, the repop channel is junk IMO, I ended up getting mine from a glass shop. Ideally, fit channel and glass, then remove to paint. On a truck with as many mods as yours, I'd want to make sure everything fits first. T/M
Old 08-24-2009, 09:50 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
I think he was asking for post fitting final assembly guidance.. before or after paint.
do it after.. use tape to protect surfaces during final installation..
Sam
Old 08-24-2009, 06:28 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Yeah, I read the original question......just stating the painfully obvious, in case somebody out there hasn't made my mistakes yet T/M
Old 08-24-2009, 08:29 PM
grumpy46's Avatar
grumpy46
grumpy46 is offline
do it after paint. just finished mine saturday. did like julie said. just take your time and don't rush it.
Old 08-25-2009, 12:50 AM
keith56_cruz_cab
thanks all
after paint it is!
