460 information???
460 information???
i have a 79 f150 that i put a 1971 460 in. what is the horsepower and torque rating on this engine because this thing ia a monster even with 35s. also i am having a problem when the truck is warm the starter cranks very slow and sometimes wont start the truck. it sound bad warm or cold... i need some helpful advice... thanks ford lovers
If you're running headers without a heat shield on your starter then heat soak can be an issue though i've never had a problem with heat soak running headers w/o a heat shield on my 390 for over 7 years now, but it does occur.
A weak, bad, corroded, rusty or greasy ground connection may be ok when the engine/starter is cold but can cause hard starting issues when the engine/starter is hot.
How much initial advance are you running? any starter kick back when the engine's hot?
Giving the engine about 1/4 throttle on the gas pedal when starting a hot engine helps too.
Which ignition are you running in this? The factory ignition is designed to back the timing down during a start to prevent this hot start issue. It is also possible that you have an advance in the dizzy that is not working properly. A stuck dizzy can create some problems such as you describe.
Check timing and advance lately?
I used to run a timing control from MSD before I went ot a mini starter.
bhs34
02-08-2010 11:47 AM
429law
12-15-2007 07:41 PM
bbfbronco
13
09-14-2005 09:18 PM
jonnybronco
03-14-2005 12:03 PM
MCalvin460CI
10-15-2003 02:02 PM
